My current scrambler project
wnyjpgy
Lackawana
NY
I've been lurking here for a little while now, so I figured it was time to post up. I recently purchased a 82 cj8, as a project. The last time it was on the road 1992, and it sat in a field from that point on. I'm sure most of know what happens to a 8 after being run in the new york salt, and then put away to pasture (literally).
Anyhow I bought it anyways with no drivetrain, other than the 300 was still there wich I have since sold, along with the 30 and 20 which are now in the scrap pile.
Since then the body has been bobbed (let the harassment start, but it was really rough) 14", the quarters have been comp cut (since the rust line was almost that high). The cab floor has been removed to make room for my drivetrain (since a want a fairly flat skid, and the cab is getting "boatsides".
I have alot of the parts sitting around for it, I wheeled a cj5 this year at a variety of places (paragon, raush creek, tellico) and determined that it was just too small, so that's the reason I have the 8.
I have the drivetrain out of my 5 still Chevy 350/turbo 350/Advance Adapter with a Dana 20. I also have a set of scout 44's, and a chevy 44 with flat top spindels. I also just purchased a used set of 36" sx's. Well I've rambled enough. If your curious about what this thing looked like when I started click on this link.
http://www.wnyoffroad.com/scrambled.php
Here are a few current pics
This is also posted in the new england section
ha! Looks great. Looks like you're going through exactly what I had to do as well. Do you have to do any major frame repair? Good luck, it will be worth all the work someday!
Welcome to the board!! :)
Looks like you're putting a lot of work into your Scrambler. And, yes, you might get a little razzing about bobbing it. Things like...'everytime a Scrambler gets bobbed, a puppy dies.' :eek: :D
But most everyone here will enjoy seeing a Scrambler built up, kept alive, and on the trails. :cool:
Hope to see more of it as you go...
Looked like it was in pretty good shape when you got it from those pictures. You can't beat $600 for a scrambler like that. Keep up the good work and take more pictures.
Pictures can be a little deceiving, the cab floor was shot, it had a couple of galvanized patches riveted in as replacements. The bed floor looked good with a bunch of parts laying on it, however after cleaning it out i was able to put my finger throught it at any given spot. Both of the fenders were shot, so I reused the tube fender I made for my 5. It had a great hood and dash (I'm looking for the factory radio volume knob if anyone has one), the winshield frame was shot but had good glass, my 5 windshild frame was rust free but had broken glass so that worked out, and there was no grill.
The frame was somewhat ok, I ground the whole thing down (what a mess) and cut off almost everything that was rotted and painted it. I need to replace about 6" or so on each side in the rear then it will be great.
I cut the passenger side quarter and rocker the other night and tack welded the tailgate back on to hold things together for now.
My square tubing will be here on tuesday so I can start the new cab floor and rocker panels. I also acquired a rust free chevy bed floor that I will be using as a starting point for the shortened 8 bed. As far as the wheel wells go I may use cj of yj wheel wells, if I can't find a reasonable set, I will break some sheet metal and bend my own.
More pics to come.
