FLCJ8
- Palm Bay
- FL
Dain looks like we both have the same goal, do anything to avoid the electrical mess.
I am sure it will be the final job.
Looks like mysunshine got the job in LA, what are you offering Dain?
Looks like mysunshine got the job in LA, what are you offering Dain?![]()
I don't have the crawfish to offer. And this is the DC metro area, so nothing great comes to mind. But if someone is willing to get the electrical mess figured out, I am willing to work on a deal. Wanna come up from sunny FL to play in the rocks in VA/WV/PA? We do have a number of nice breweries that I can bribe someone with as well.![]()
There ARE good reasons to come...[emoji106]
Not much progress today. But progress anyway. I was able to get the front brake bleeder valves out finally. Took a bit of heat. I was able to get fluid to get to both front brakes. Then I undid the rear line at the proportioning valve. Fluid comes out there. I will keep going back along the line tomorrow. As of now, no fluid coming out at either rear brake.
Check out pages 2G-25 to 2G-27. Depending on what type combination valve you should pull out or push in the metering valve stem to properly bleed the brakes. http://oljeep.com/gw/82_tsm/Part 2 Section G.pdf
I also had the same issue of not being able to get fluid to the rear recently when re-doing my Jeepster brakes and was able to take care of it by loosening the fitting to the rear line at the master cylinder and pumping until I had a good flow of fluid there and then bleeding normally.
There are metal brackets that bolt to the top of the back inter wall. The cable mounts there and will correct your problem. Also where you have yours you loose a lot of leverage. It puts more strain on the tub where yours are mounted. Here's some pics (I know they are not the best, jeeps are at my shop so can't get you a good pic.View attachment 53435View attachment 53436
Jammer beat me to it...but here is my contribution:
I almost feel bad that I don't have any exciting build stuff to post...since I don't really have to rebuild anything on mine. It's just been cosmetic stuff like repainting the rear bumper and the bed...installing new carpet, etc. Well...ok...I don't really feel that bad. I feel more lucky than bad.
My cj7 has a fiberglass body. Let me take a pic to see how I mounted it with the fiberglass body. Yours may be mounting bolts directly through the fiberglass wall using large washers to spread the load. Brackets won't fit on yours the way yours is built.
I sit and stand on mine with no problems
