My De-Rustification Project
Yes, the cj7 has a fiberglass body, metal tailgate. I just need to check how I anchored it.
So I am trying something to diagnose if I have a problem with the connections at the firewall. So I created some short wires to go between the connections. I have to go to work now, so I will connect the battery and see what happens tonight.
I wanted to test this as i was wondering if when I plugged the parts together some of the males were not making good connections with the females on the other side.
Grocery shopping so not able to test it out yet. Hopefully later.
Grounds. Grounds. Grounds....
Sorry, had to start with that. Keep plugging away. If you're not done by tax day I can come down and help if you need another set of eyes.
Thanks. I know grounds can be a pain. Odd thing about my crappy wires is that things in the cab are grounded different ways and all are not working. But I know it can still be grounds.
If I don't find anything with these connections, I will look to getting a hold of a power probe and seeing if I learn anything with that.
I'm from the school of Jeephammer so I went overboard on my grounds. I used one of these to get a guaranteed ground into the cab:
https://www.bluesea.com/products/2203/Terminal_Feed_Through_Connector_-_3_8in-16_Studs_[Black]
This includes dedicated wires I ran to the heater, the wipers, and in the loom to the back for gas tank and taillights.
In the engine compartment I have 4 gauge wire going from battery, engine, alternator, etc to the other side of this.
Well. Not sure what is up, but I now have interior lights and the gauges that should work, do work. I also fixed the wiring to the headlight switch so that the headlights and high beams both work. Would the wiring at the headlight switch being wrong cause all of the other stuff to not work? Because until I switched those wires, things were still wonky.
I also noticed that I don't have a working rear tail light on the driver side. But that could be something unrelated. It worked before tonight. But the whole housing is loose now too as I have been bumping it a lot working on stuff walking around it.
So I guess I had a little progress tonight. I guess the real test will be when I pull all of my little wires and reattach the two harnesses with the bolt.
Oh and I have a very high idle. Need to adjust that.
It had been too long so I tackled a few little things. Tidied up the wiring at the high beam switch, ran a ground for the trailer hitch wiring harness, ran a ground for the fuel sending unit, put the flat hex screws in the pass side mirror and fixed the tail light that was out. Loose connection at the harness in the rear.
Still need to run the positive on the fuel sending unit but will need to cut an access panel in the bed first. And I need to figure out why I don't have reverse lights.
I will be tackling the rear brake bleeding as well. Those and the reverse lights need to be done before inspection. Grrrr.
Oh yeah. That idle. I think I screwed something up when attaching the throttle cable. I will tackle that another night as well.
My list is not getting shorter.
I did the same on the fiberglass cj7 and the metal cj8 build. If I ever had to I could re-weld the door back in but this is minor compared to what others do with trimming the wheel wells etc. On the last change over to speed hut gauges and sending unit made connecting everything a breeze.
I will be making the cuts soon. Just need to measure it out and make sure I don't hit any of the hoses. How big did you make the access panels?
Just a suggestion, once you determine the size opening needed you may want to look into these:
http://www.searay-parts.com/Access-Door-Hatche-Plate-s/45.htm
If you pick one to fit the size opening (or slightly larger), it would be very easy to cut a nice clean opening with a finished look.
Those are pretty slick. Thanks. I had not thought of that. I was thinking of aluminum sheet with screws or at most a piano hinge on one side.
Dain, are you sure, I don't think there is a positive to a sending unit. Only a sending unit signal and a ground on most.
Bad choice of words on my part. The sending signal wire was what I meant. Just could not put it into the right words. But thanks.
