Grounds. Grounds. Grounds....
Sorry, had to start with that. Keep plugging away. If you're not done by tax day I can come down and help if you need another set of eyes.
Thanks. I know grounds can be a pain. Odd thing about my crappy wires is that things in the cab are grounded different ways and all are not working. But I know it can still be grounds.
If I don't find anything with these connections, I will look to getting a hold of a power probe and seeing if I learn anything with that.
Still need to run the positive on the fuel sending unit but will need to cut an access panel in the bed first.
Don't cut the bed!
What!Don't cut the bed!
I did the same on the fiberglass cj7 and the metal cj8 build. If I ever had to I could re-weld the door back in but this is minor compared to what others do with trimming the wheel wells etc. On the last change over to speed hut gauges and sending unit made connecting everything a breeze.
I will be making the cuts soon. Just need to measure it out and make sure I don't hit any of the hoses. How big did you make the access panels?
Just a suggestion, once you determine the size opening needed you may want to look into these:
http://www.searay-parts.com/Access-Door-Hatche-Plate-s/45.htm
If you pick one to fit the size opening (or slightly larger), it would be very easy to cut a nice clean opening with a finished look.
Dain, are you sure, I don't think there is a positive to a sending unit. Only a sending unit signal and a ground on most.Still need to run the positive on the fuel sending unit
