bones
- Dearborn Heights, MI
- MI
I hear this is a common failure, especially with dual cases.... This was the first time I have had everything in low and really got on it hard it a rutted/iced hill. Front end popped up off the ground and when it came down the front tires bit hard and something had to give.
Here is how I have the setup. the crossmember suports the trans/cases just after the trans (the first crossover bar, you can see the 2 heads of the bolts).
Here is the crack.
Drivers side- the adaptor to the right of the crack and left of the orange silicon is the plate that runs down to the crossmember
pass side
So I am going to add a second mounting point near the rear of the 300... Maybe on the output shaft housing that crosses over the second part of my crossmember bar
Here is the crack.
pass side
couldn't help it!
