- stafford
- va
no !
i have sold several full sets for $50 on ebay
i will check my shed,i may have one
good infoGreat starting point. I love the Laredo's too. Check your year though. I believe Sebring red started in 83 as did the 3 pt. seatbelts, which you have. Oriental red was the color for 82. I am not sure if the later models for 82 had 3 pt belts or not. I am sure someone here could say ...
you pay shipping
1. Don't mess with the shackle length until you get the correct springs mounted.
- I was going to get tires mounted and a sway back on it an determine where to go / how much spring I needed. Looks like the shackle reversal will accomodated 2.5" YJ springs. Thinking about a 2.5" YJ kit? Any thoughts?
With the long shock towers and shocks, I was thinking of keeping them. How old / what are they? Do you remember?
2. The tie rods were flipped because of clearance with the long-travel springs that were mounted on the Jeep before.
Sounds good!
3. Unless somebody else in the past couple of months has screwed with the timing, don't mess with it. I recurved the HEI myself and set the total timing on the dyno using emissions equipment.
I'm not sure if it's still burning out the grime from sitting. It idles pretty low, but then usually stumbles right off idle, once past that point it's pretty smooth. Keep in mind, that I got it on "rollers" so I don't have 20 miles on it yet. I hope to have it on real rubber, and putting miles on next wednesday; so I will have a better feel then.
4. The Ford shock towers were installed to mount a shock with enough travel for the LT springs. If you are not doing anything oddball with the suspension, I'd just hunt down some stock shock towers and bolt them in the place of what is currently there. That also will help cure the shock mounting angle.
