My turn!
On the steering column/intermediate shaft, is it supposed to separate above that sleeve that the bolt is removed from?
attachment.php
Yes, that's where it disconnects to remove the column. PB Blaster/Kroil/Etc and some hammer taps may be in order. I believe there's plastic bits in the end of the column that might be destroyed with heat, but you'll want to get verification on that.
Yeah, that wet look you see is PB Blaster. I got to get another can of that, it's getting some pretty good use :rotfl:
Well, I don't know if I'm prying/hammering on the wrong part or not, but this sucker isn't budging.
I realized I didn't clean the pb blaster off well enough when I used a propane torch :rotfl: It got a little warm :rotfl:
Ah well, pictures of progress coming soon...
Yes, those plastic bits can be destroyed by heat. Or by putting a pry bar against them. There's a kit available that has all the end pieces together if you break them though (check eBay). But either way, that joint is a PIA. Clean the splines well and liberally use anti-seize when reassembling.
when I removed mine I pulled the entire column out through the dash.. everything from the steering wheel to the joint at the gear box in one long piece... that made it easier to separate the upper/lower portions once it was already out..
the lower connection at the gear box can be split with a tie-rod or ball-joint fork, as it is a bit narrower
I'll be following your project.. great start!
One of the advantages of knowing you're going to trash the body is that you can trash the body to get to bolts you couldn't normally get to with a cut-off wheel :rotfl: (pics 4 and 5)
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Man I was so happy when you said you were going to trash that body.....
What's that bracket just above and to the right of your gas pedal?
Really? Interesting. Did they put that in there no matter what trans they ended up installing?
That would be even more interesting, since I think the only CJs that came with the 400's were the ones that had the Quadra-Trac system installed. But my memory is a little fuzzy on that.
The block is out and on a stand. The crank turns, so that's the best news. The bores are already .040" over, but the walls look to be in pretty good shape. No ridge and no obvious scrapes. A simple clean-up hone oughta work just fine.
Crank is standard on the mains, .010" on the rods. I'll have to hot tank it and polish the journals to see if it can stay there. Didn't feel any obvious signs of nasty wear on the journal of the one cap I took off, I have a feeling that can also stay where it's at.
All the bearings are Clevite 77, so that tells you how long ago that was done :rotfl: I forgot to check for a date code, some of the earlier ones had them...will update later with some pics of general crap :D
Date codes were March of '93 on the mains and January of '95 on the rods. Paperwork says replacement motor was installed in 96, so that makes sense. Anyways, on with the pictures.
New Years Day seemed like the perfect time to head into work and get some more junque stripped off the Heep. No phone calls, peace and quiet! Dropped the trans and transfer case, which is fun when the wheels are still on the ground. I envy you guys that have access to post lifts.
With that out, I'm moving on to undoing the body bolts. Some are easier than others, since parts of the body have rusted so badly that they're not even attached to the frame anymore :rotfl:
I'm contemplating making a wooden dolly out of 2x4 and steel casters so once the body comes up, it can be tilted onto its *** and rolled around, out of the way. The guys at Willys-Overland (if I go that route) recommend I keep the body in case I need to measure stuff.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
OK, so this is half shameless plug, half drool-worthy for me. I started up my own blog of the build since I'm registered on like 7 different Jeep sites. I tooled on over to jeepforum.com for the first time in like a year in a half, and somebody had posted pictures of the 7 version of my 8. Absolutely beautiful restoration job.
http://amanandhisjeep.com/?page_id=73
If I can get mine looking even close to this, I'll come away happy.
