need spare tire help
ThisBearBites
Specifically - my spare frame rattles so bad I finally took it off. It has busted itself twice from the vibrations. Can't keep welding it - I need to get to the source of the problem. My guess is something is missing. Many, many parts were missing when I bought this scrambler. The last owner abused her bad. She barely ran or rolled. (She's a dream to drive now!) But, I can't find a good pic or description specifically to the original look of the spare tire frame. It WAS attached to the jeep body with just a couple of long bolts and nuts. I suspect there needs to be more to stop the movement.
Can any one help?
If you have anything larger than a 30" tire back there it is going to rattle itself apart. I hate those factory racks. The rack on my CJ7(32"tires) is the only thing that rattles and it drives me crazy. For my Scrambler(35"tires) I built a bumper mounted tire carrier(no rattles). The factory carrier is held in place by 6 bolts to the rear of the tub. These bolts are for the 2 hinges, and the latch. Those bolts are part of the actual brackets, if I remember correctly. There should be a support bracket mounted inside the rear passenger corner. This bracket should support the bottom hinge, and be held in place by the 2 bottom hinge bolts, and 2 bolts on the inside of the tub. That is it. I don't know of any other bolts/supports for the original carriers.
Later,
spare tire
Thanks for your advice. For now, I think I'll just leave the spare and frame off. The lack of rattle has been sweet. Probably this fall I'll modify my set up to make it sturdier. Summer is just for play time and emergency maintenance only! Spring and fall are my project times. I'm a purist - trying to keep my Scrambler as original equipment as possible. Sorry boys! The last owner trashed her bad. Been a lot of research time and tinkering to bring her back. Transmission will be my next big project. Body work and paint will be the final stage, that's the only place I might waiver from original. I want to stay original, but I also have a lot of artistic ideas!
