1x1_Speed_Craig
Simplify...
- Greeneville
- TN
I have mentioned before that while I continue my Scrambler restoration, I'll also be working (intermittently) on building up an '86 CJ-7. Since the Scrambler will be primarily road-driven (90% road/10% offroad estimated), I'd like to do something a little different with the CJ-7.
What I'm working with (currently have):
* Single-owner '86 CJ-7, 258/T-5/D300, Dana 30/Dana 44 (3.31 gearing), seems to run well, ~130K miles, resembles swiss cheese. Frame & tub will both be replaced. Although it runs well, I haven't driven it on the road due to the condition of the frame/tub, and it's not currently licensed.
* Replacement '85 CJ-7 frame already purchased ($100), overall good shape, but needs some minor repair. Set of 6 new AFW frame mounts have already been purchased. A semi-local fabricator (shop owner who's active on the Michigan Jeepers board) will be installing M.O.R.E. front frame plates, new body mounts, and new rear crossmember. He'll also be plating the rear of the frame a little for additional support (to fix small soft spot on inside rear of frame by rear crossmember), and I'll give him some creative freedom to beef up the frame as he sees fit.
My goals:
* Build a light, capable offroad vehicle since the Scrambler is going to be babied somewhat (mostly road-driven).
* Keep an open Jeep...no doors, and a bikini top at the most.
* Use 31" - 33" tires, and minimize lift (2.5" - 3")
* Maintain streetability. Even though it'll be more capable offroad, I want to be able to drive it on the road regularly, including driving to trail locations.
* Maintain current 258 6-cyl./T-5/D300 combination.
My thoughts on accomplishing the above:
* Keep stock D30/D44 axles. Locker in at least the rear. Some sort of road-friendly (selectable?) locker in the front. Since streetability is a goal, and my maximum tire size will only be 33", I'm thinking about keeping the 3.31 gears, and reducing overall gearing by using a Tera-Low kit (or something similar) in the D300 transfer case. That'll give me low offroad gearing, and mileage-friendly street gearing.
* Mild 2 1/2" lift (and maybe a little bit of shackle lift) with 33" x 9.5" tires that will tuck well. Use of tube fenders on front will help with clearance (nudge, nudge...Randyzzz). Tub (TBD) could be trimmed in the back. I like the appearance of smaller lifts, and it'll give a lower center of gravity for on-road and off-road driving.
* Since this won't be my primary vehicle, I'd probably install the 258 as-is (not rebuild), but may try to rebuild the T-5 myself for more dependability and the learning experience.
So there it is. Feel free to make suggestions for things I may want to consider, as I'm just in the planning stages...I definitely value all of the knowledge and suggestions from you guys. The replacement frame work, however, will be started within the next couple weeks.
Thanks,
Craig
My goals:
Thanks,
Craig
