new member, full hard top questions
jim03
Brookville
IN
I have been coming to cj-8.com for years but have somehow never seen the forums. A little background first. 83 scrambler 258 w/ header, weber, and HEI, and four speed. currently in the processs of building one piece amc 20's and adding 2&1/2 inch springs. Now my question. I had been looking for a full hard top for years and had almost given up. About a month ago I happened to find one just about 30 miles away. It is in decent shape but the best thing was it came with a scrambler and the whole outfit was only $1000. Sure, the jeeps not in the greatest shape but I was able to drive it home and it is going to make a great project for my father in law. The full hard top is going on my scrambler and I would just like to get a little info on it if anyone knows much about these. It says "Classic" across the back above the rear window. and has sliders on each side. The hinges on the lift gate are severely rusted and almost look like regular door hinges. Where these the original style or has someone changed them out. Also if anyone knows where the best place to get new weather stripping for the gate and windows that would be helpfull. Thanks
Welcome aboard
I don't know anything about the hard tops,other than the stock 1/2 cab-send donaghy a privte email and ask him,he is pretty familar with the full hard tops and maybe even to help you out on the parts-mine hasn't had a top on it in three years and no i don't live in a sunshine state-JC:D
The Full Hard top was never "Original" though was most likely available from some Jeep Dealers as an add on at the time of purchase.
I had a full hard top (ACME TOP) and it used the exact same hardware that the stock CJ-7 tops used, hinges, rear lift hatch, tail gate, as well as all the seals.
After driving it around with the FHT I decided it was to noisy and wasn't happy with the fact that the top adds an extra 300lbs to my Jeep. The extra weight will , over time wear out your body mounts.
Don't get discouraged about running your top, I just figured you should know the consequences of a FHT.
the body mounts that are now destroye dare the mounts on both sides of the Jeep that ar located behind the Driver and passenger seats, infront of the rear wheel wells. Mine are dust.
I believe there is a company that is making Scrambler FHTs now. You might want to look to them for more answers.
Good luck!
I have fht, that I used to think was made by grizzly but not so sure any more. I see spring scramble pics to see a photo, as far as I know fht were made by AJ's, ACME, Topflight (the newest and still available, and Grizzly. I like my fht, the disadvantages are the following.
It is very heavy (mines like 8001b or so but it has especially heavy construction. I experance spring sag in the back (could be over sized gas tank and all the shit I normally carry with me too) It restricts visablity some but found it easy to live with and my windows are smaller than most tops that I have seen. It is very difficult to remove by yourself even with a handy maple tree and some rope. The advantages for me are a lockable cavernous interior that can sleep in. It will make your jeep stand out a little bit. I have found the interior dry and quiet.
Thanks for all the help on this. I agree with everyone about the weight. I it very decieving, it does not look nearly as heavy as it is. I am getting ready to replace the rubber mounts with poly so hopfully this will help. I am still wondering if CLASSIC is the brand name or if it is mabey just a model name from one of the manufacturers everyone mentioned.
:eek: DUDE!! :eek:
Using POLY MOUNTS will crush your body worse than the stock (soft) rubber bushings will!
Like I said in my previous post the body mounts behind both the driver and passenger are crushed beyond repair on my ride. I have all poly body mounts and these two are the only posistions with problems.
If you do go for the poly mounts I would suggest two things.
#1 replace all but the two body mounts described above with Poly bushings. Save the best two stock rubber bushings you have and put them in the above mentioned posistion. It's my opinion and belief that the Scrambler extra wheel base causes these two body mounts to twist more that the same mounts on CJ-7s thus causing the extra wear on these mounts. By leaving the rubber bushings in there you will reduce the wear on your body.
#2 If you plan on following #1 buy the CJ-7 Poly mount set. It will come with all the needed bushings -2 sets (the ones you will leave stock) and you will save a couple of bucks (like $20.-$30. if I remember correctly!).
Good luck and happy Jeepin!
Mark
Classic
I have the same top on my scrambler. You are correct, it is heavier than it looks. There have been posts on this board about this type of top, and it is compared to grizzly top. As for the hatch shocks good luck, but I believe the OME CJ7 hardtop hatch will fit on your top, ? on the shocks. Danny
SORRY MRMARRCO
I missunderstood what you were saying. I see what you mean about the extra weight and length possibly crushing the mounts and I agree poly would only aggrivate this. Thanks for the tip.
Hinges
Sorry Jim, I was thinking of my top when I wrote the reply. You might try hinges from a CJ7 hardtop. The CJ7 hardtop hinges and lift gate looks very close to our top. If I ever get a day off from work, I will swing by the local jeep yard to see if the hinges will work. Dan
Thanks CJ8Dan. I have a old set of hood hinges laying around that I was looking at yesterday. I think with a little cutting these would work pretty good.
I have a acme full hard and I'm looking for the adjustable clips that hold the top on.Thanks for any help.
Thanks, Larry
