New Product Reveiw
mulescj8
INSANE SCRAMBLER HACK
Tn
Off Road Engineering's Eletronic Hand Throttle Control for Fuel injected and Throttle body engines:I finally got around to install my unit that i bought several months ago.I bought the upgraded version with the optional wired remote hand control.The People there are really nice and you deal with the owners direct.This thing is a no brainer on the install the leads run out to your TBI or FI idle controler,unplug it and plug it into the harness and then plug the harness to the where you unpluged the idle controller,then you have a hot/switch/fused wire to connect and a ground,then plug the remote in and your done.You can run your idle from 0 rpms to 3000 rpms with the flip of a switch and as long as the power switch is on you can set your idle to where you want it for Rockcrawling,running your on board air compressor,welder,winching or just to jump off another vechical,when your done turn off the power and your idle is set back to stock.Nice product that works and it won't bankrupt you to buy the unit,It's small and easy to mount and install,I'm ready to hit a few trails and see just what it will do.You can check them out by calling 949-581-2991 or at www.offroadengineering.com JC:D
How is this better than the manual throttle controller? I've been leery of the electric 'cause I'm afraid it may disagree with me and drive us into a bad way, can't happen?
Electric VS Manual hand throtle
They both do the same things and here are the pro and cons as i see them:
ELECTRIC:PROS
1-this unit only takes about 30 mins to install and most of that is just time trying to decide where you want everything.
2-It can be turned off to completely disable it.Can be turned off with a flip of a switch if needed.
3-There is nothing that can't be undone in about 10 mins to put it back the way it was.
4-There is nothing that attaches to the throttle lever or the throttle cable
5-It can be operated outside of the 4x4
6-It can be adjust up or down in 100rpm adjustments.
CONS:
1-Cost it is about $200.00 for the top of the line model and about $150.00 for the economy model.
2-Will not work on Carbed engines that are not computer controlled.
MANUAL:PROS
1-Very cheap to build and parts are easy to get from any place that sells Bike parts
2-Works just as well as the electric.
3-You will have more money in your pocket for the extra beer that your buddies will drink while watching you work.
4-Will work on carbed engines
CONS:
1-A lot of time will be spent trying to figure out how to hook everything up and keep it from binding or hanging up.
2-Another cable to contine with that has to be routed out of harms way and where it won't bind up.
3-Adjustments to the idle are whatever,maybe 100rpm or 300rpm and not constant.
4-Can not be disabled with out unhooking it.
5-Cable could bind and not be able to shut your idle down in a hurry if needed.
6-It has to be connected directly to the throttle lever or cable to operate.
