I have these for mine. Have them installed but not painted yet. My advice would be to mount them unpainted first to avoid screwing up the paint which seems likely if you do it the other way around. This is why mine are mounted but unpainted.
The ease of mounting them is a function of the condition of your body mounts. The rockers go inbetween the body and mount in two locations on each side. You have to get all of those bolts out, remove and cut 3/16" off the top of the body mount bushings to allow the rocker plating to fit and then reinstall the bolts after mounting the rocker. The corners and top edge of the rockers require a whole bunch of 3/8" (IIRC) holes for the bolts to attach to the tub.
BE WARNED that there are often problems with the body mounting bolts coming out (and there's no way around removing them all for this install). Mine were in well above average shape and I still broke two off in the body. I have yet to go in to fix them, but you should NOT drive it without these being fixed. Start soaking them in PB blaster (if you can get to them) now. I would recommend using all new body mount bushings. They're not that expensive, much easier to cut the ones you need to shorten and your stock ones WILL be in bad shape (20+ yo rubber).
If you ordered the standard corners, you really have no choice but to go with LED lights, they're only cut out for those. You can't mount up the standard Jeep lights without modifying the corner and I'd bet they wouldn't cover the entire round cutout that's already in them for the LED lights. Also note that there's no provision for reverse lights, which should be required for inspection. So you'll have to work something out to make new reverse lights. I was going to mount one or two small lights on my bumper.
