New to Jeeps
whitcmiller
Shreveport
LA
Im new to the Jeeps, i just got an 81 Scrambler and im looking to do an engine swap on it to a short block 350, just looking for some advice/guidance and opinions on this. The Scrambler has a 4 cly in it now and i was also wondering about the transmission. Any gudance would help.
An 81 with a 4 cyl is the Iron Duke- the bellhousing pattern already fits the 350! It's a pretty easy swap. I have most of the details here somewhere...
Found it...
Ok...I searched my old posts and found my "Build List". Hope this helps.
Oh, I did eventually go to an aluminum radiator by "Northern", the Tellico unit needed something resoldered avary 6 months... And be careful with the T176, mine finally bit the dust a few weeks ago(But I have been pretty hard on it, and it did have over 280K on it!)
Here's the list...( I was converting from a "Iron Duke" 4 popper)
1. Motor mounts- M.O.R.E
2. Headers- Hedman "Tight Tubes"
3. Radiator- from Tellico 4X4, about $189.95, works fine.
4. Hoses- Napa # 7470 and #7575. Not sure which is for the top or the bottom, I do remember the bottom had to be trimmed at one end.
5. Power steering hoses- I had Napa make up some compression Fitting splices to fit two hoses together. Works great.
6. I used a stock long water pump with a stock fan clutch, stock fan, and a Commando V-8 shroud. (a cj V-8 shroud should work too).
7. The stock bellhousing fit the Chev 350 motor, find an "iron duke" bellhousing for your swap.
8. Use a 153 tooth flywheel, a diaphragm pressure plate Napa CA1897, and a Napa RCF 556 10.5" disc. This is the combo for the T-176. Use the stock 82 T-176 throwout bearing, and keep the stock hydraulic clutch setup. You will need to file one of the slave cylinder mounting bolts to clear the oil filter, you'll see...
9. The trans mount is attached to a plate which cantalievers the mount backwards. Reverse this setup, you will need to drill new holes in the skid, but they will be on a level area. Again, you'll see.
10.The rear driveshaft is ok with a 4" lift. The front is extended a little too long, but I haven't overflexed it to pull out (yet).
11.The GM hei distributor needs a strong 12v power feed, one of the existing wires will work. Also the temp and oil pressure senders on my 350 were compatible with the stock gauges.
12.I got rid of all the other wires...I hate clutter. Oh, and I used the stock "iron duke" starter...and it cranks the 350 with authority. The GM starter has a built in solenoid, so you can loose the external starter relay and associated wiring. Positive cable to the batt terminal on the starter and the "hot in start" wire to the ign terminal on the starter.
13.I used a stock mechanical GM fuel pump, and capped the tank vent hose.
14.For a daily driver manual trans, the T-176 trans is ok...a little slow between shifts, the 350 builds revs fast. I like the T-176 mostly because I cant justify the $$$ for a NV4500. I am going to a 700R4, I want overdrive with my new 4.56 gears, and my scrambler is a daily driver (50 mi/day) and I am getting too old getting tired of shifting. The TH350 is a great trans too...but with either auto there are going to be clearance problems along the right side of the pan.
15.Everything else seemed to fall into place...but every swap is different. Good Luck!
__________________
I'm going to guess your transmission is either the original SR4 (hard to believe it would have made it this long, though), or the T4 or T5. Give us the shift pattern, i.e. where reverse is, and a description of the shifter, i.e. straight, dog leg, etc, and we can tell you what's in there.
If it's the SR4, you'll need something else behind the 350. You'll need something else sooner or later, in any case.
thanks for the help, i am going to try this out, i am sure i will be back for some more advice later.
First of all that short block will not run very well without the intake carb and ignition. :shrug: I kid I kid. :rotfl:
icky, sounds like the SR4. If you've got deep pockets and are considering the GM 350 engine, you may as well go with the T176 transmission that Randy uses in his post.
