You have very good vision Big Walton! I can take the drive shaft and move in about a 1-1/2 inch circle all the way around the housing.
panther said:
Try and get it running the best you can. Can you crank the engine at all?
I put a new distributer cap, ignition module, plugs and wires on it just to have the starter not work. So I'm saving some money to purchase a new one. I also plan on trying to get this one working, take it apart and check out the armeture etc... so to answer your question, I can't get it cranked, until I get a starter. I'm trying though...
In everyones opinion, should I worry with trying to get it running first, or just pull the motor and go for removing the tub and start on the rust. With that said, what's a good frame paint?
I wanted to start a post under the other section, so if I'm out of line, then just start another thread somewhere else and let me know
My plan for the rust was this...
1 - The windshield and bulkhead are completely gone, so I thought I would remove the half-top, take both the windshield (after removing the wiperblade equipment and motor) and bulkhead out. I'll buy new ones to replace those.
2 - In the back, where the rust is the worst. How do you weld in to replace those holes? I would assume a very low setting on a mig welder and then some grinding / bondo / primer / paint. Is that how it's done? I can't afford a whole new tub, and the crossmembers for the tub are in good shape, just some surface rust, so I thought I would make this one work. The floorboard is in bad shape though, alot of holes and thin metal. I don't mind welding in replacement metal because I plan on soaking this thing in Rhino lining from floorboard to tailgate when done. Do you guys need more pics for assessment? I'm in the beginnings here, where should I start guys?
Thanks!!!!!
http://plaza.ufl.edu/rt826jw/scrambler/cj8.htm
