No left turn
Wyoming
DC
Cheyenne
wy
I need help. I took all the wireing out to paint. When I got it back together I have no left turn blinking. It works ok on the right. On the left it will turn the light on dim but won't blink. I changed the blinker traced it down the blinker shares the same wire for both sides, it seem like it splits from the turn signal switch. This is new and I tried another one it still works the same. I can't find any wires shorted or pinched. I cut the wire that feeds the turn signal at the conection on the colum, then testing it with a test light it is still dim there. The right is nice and bright. And blinks. The emergency flashers work fine on all lights. Any ideas?
Dennis i did the same thing kinda of..............didnt know the rears share a common ground between the turn signals and tail lights...........had to run a wire between the two since i wasn't using the body for a ground anymore......check your grounds and make sure your buckets are grounded really good and that you don't have anything rusty or loose.....even a bad bulb can cause this.................
