No power to transmision????HELP
The Real CJ8
Small wheel
fredricton
NB
OK I need to plow my dooryard as we just got a ton of snow...
I go out start up my jeep, push in the cluch. Put it in gear and nothing...
I used my jeep to plow two days ago and now nothing????***
As far as I can tell the t-4 transimison is not getting any power, it shifted fine before and now nothing....What the heck is going on??????
When I push in the cluch I feel resistance.
temp is -6C
PLEASE HELP...
joel
Check to see if the transfer case popped into neutral. It's happened to me.
Yup I tried shifting the transfer case with no results....I tried letting it warm up for about 30minutes.....I tried reving the snot out of it.....
I tired to shift the transmision into gear with out the cluch and it does not seem that anything is turning inside, it just goes right in no grinding.....:confused: :confused: :confused:
Theres nothing like layin in the snow in the cold working on a jeep:rotfl:
It's bothering me that you can shift it while running (even while revving up).:confused: First thought is disintegrated clutch or broke input shaft....neither of these just happen for no reason...I think you would have known it when you shut it off after last use.
I still suspect transfer case! But I may be wrong.
If you thought that the transmission was turning while in gear I would say that the set screw came loose on a shift fork in the tcase, but if you say that nothing is turning in the tranny then i would start looking into the trans. but man get it in where it's warm. when all this started did you have to shift the transfer case or did you just get in and wala nothing?
When this happened to me, one of my sons was playing around in the Jeep while I was doing something. I got in to move it and nothing, wouldn't move. I was ready to pull the transmission when I realized what had happened. Foolish feeling, but big relief.
Inspection Cover
Pull The Floor Pan Out, Remove The Shifter......open The Top Of The Transmission And See If Your Gears Are Moving....if They Arent You Have A Clutch Problem, If They Are You Have A Transfer Case Problem......let Me Know Im Curious. The Top Trans Cover Should Come OfF As Easy As The Floor Pan, No Sweat
I think you where right MOPEDAL not mutch clutch left
Makes me think what caused it.... I must say I was not too easy plowing with my scrambler. High revs with the clutch only partly in. I feel guilty but I need to justify owning the Scrambler for my wife. Must be a tool instead of just a money pit.
Joel
