Noobe Ques: 35" Tires/How'd this guy do it?
Patrick_Arnold
Gambrills
MD
This rig looks pretty sharp: http://www.jeephead.com/images/1985s/85134726b.jpg
He says he is running 35's. Does this look like it would have clearance problems? In general, is it possible to run 35's without lots of problems? I am planning on new springs with a reverse shackle kit most likely. Up to now I was planning on running 33's on 15" wheels.
I realize many of you have been through this countless times with folks before so I appreciate your patience just one more time --not!
Pat
Another Defaced Scrambler.....
Is it possible, certainly it is. However, that one looks like it will rub the tires. He could have some big bump-stops on it or something. With those headlights, I hesitate to say, but it does look like someone put a lot of time and effort into that one.
I do
Well as of Today I was running 35" BFG's for street tires and 35" Boggers for off-road tires and they fit perfectly with my spring over (they would tuck into the wheel wells just right with out any help of bump stops)
http://www.texasoffroad.net/albums/txtrailriders/TreesMemorial2004/Gayton0_R1_028_12A.jpg
Boggers are 16" wide and once in a really nasty bind I cracked the front passenger fender flare but not noticeable. I have custom Wrangler springs w/ military wrap up front with custom front spring brackets. For the Rear I have added extra leafs to the stock spring pack and made custom lift shackles. Well now I run 37" GoodYear MTR's and bump stops are going to have to be added...pics coming soon.
It is probably a street only rig without much flex if he did take it on the trail. On stock width axles, he may also had to adjust his steering stops to keep from rubbing.
I am running Waggy axles which are 4" wider than stock in a SOA setup which equals about 6" lift. I don't rub when stuffed and turned but its close. Will probably get some rub when I have to buy new tires and go to 35 BFG-MTs.
forum
