O.T. - Pole barn suggestions
Craig, if you hunt then add the hoist for the hard top/big game... you may want to add a mechanics Pit since thats a lot cheaper then a lift... Sounds like a sweet deal though. Hope you enjoy your new digs!
TK
Wow Ed, that's a SWEET looking pole barn. :)
Tom - I don't believe mechanic's pits are legal in Michigan, but I'll have to check into it. Thanks for the tip. No plans for hard tops or big game at this point (soft top on Scrambler and I'm not a big hunter...unless I get a REALLY big bunny at some point). :D
Eric - No, it's not in Durham or Raleigh. :) I'd love to come down that way to live/work, but my wife wouldn't go for it. We have also found a great church here (I have gotten more out of going there in the last year than I have anywhere else in the last couple decades). My oldest daughter is actually registered for Kindergarden this Fall (wow, time goes quickly), and I'm on the Township Parks & Rec Committee. All of these things are leading us to stick around here. Any chance I could telecommute, though? :D
Everyone else - thanks for your input!
Craig
I would have a laundry sink next to my refrigerator that is just below my tv. You have to mount the tv high so you can see it from anywhere. By all means slope the floor to a drain. Have it draining to a buried drum that can be pumped out when no one is looking. I also think you should run tubing in the floor even if you don't hook up to a boiler yet. Someday you will have a little extra money in your budget and you will wish you had done it. My neighbor just used a hot water heater and a few ball valves and a pump to heat his shop and it works good. If you were going to keep your shop heated all winter, floor heat is the cheapest way to go. Lighting is everything especially the older you get. I installed 6 eight foot flourescent double fixtures in each bay and one over the work bench. That is good light but if you don't use electronic ballasts the noise will drive you nuts. Its total quiet now that I have changed to electronic. If you are going to insulate and sheet rock be sure to run wire for recepticals high and low. High for the retractable drop lights and beer signs and low for the tools and equipment. If you work on low ride vehicles a greese pit would be nice too. If you can't afford all this stuff go borrow the money, it will be money well spent:D
Suggestions on what kind of industrial paint (or other material) to use on the floor for easy clean-up? I heard some of this stuff is pretty toxic/scary to work with.
Thanks,
Craig
A carport on one side is nice have and adds little to the price if it doesn't have a cement floor. A cement floor under a carport costs more than the carport itself. Good for parking extra vehicles under for bad weather, or BBQin in the rain.
It sounds like you're having a kit building put up. Check with custom metal building builders. In the south texas area a kit building costs about 80% of what a custom built building does, and then you have to put the thing together or pay someone to do it. And you're stuck with a standard building, not as many options.
I've built over 300 buildings, and the best accessory I've seen in one is an overhead hoist. Some put them on a single straight track, or it can be put on an oval track to give access to more of the shop. My dad's shop has a 19' long I-beam the swivels on a pole, and a chain hoist trolley runs on it. I can pick up one end of jeep and set it on our nice 8" I-beam table to work on suspension or such. Sky lights are also nice.
As for the Epoxy Garage paint I have actually had good luck with the stuff from Home Depot. It is not too expensive and seems to work OK. If you have a choice get the kind with multi color chips that you can add to teh surface once it is rolled out. This speckled look actually helps hide dirt and stains.
I actualyl prefer the tan version. I have the grey in my shop and the tan in the front attached garage. For some reason the tan seems to reflect more light and makes it easier to see things on the floor.
Th HD paint is pretty easy to do you get two cans and mix them together at the time that you want to paint. Use one of those rods taht you attach to a dril to ge tthe stuff mixed real good and realize that since it is an epoxy what ever you use to paint/roller it on with will need to be thrown away. No cleanign that stuff off. It is pretty easy.
You might also look at the local paint distributors and see if they can offer you a commercial version. Should work the same way, but you might have to buy in 5 gal increments.
Carl
