So I got back to this today and bought a new Idle Air Control (IAC) valve. Replaced in about 5 minutes. Reset the ECM per S10 FSM (neg battery disconnected, key on, key off 5 seconds, key on 10 seconds.) Took it for a test drive and it's still stalling out when I'm driving. Specifically, I will engine brake and as soon as I push in the clutch to take the load off the engine, RPM drops to zero. Bump the clutch and the engine restarts no problem. It's a little frustrating and a distraction while driving. I am relearning to not engine brake, but use the clutch and brake.
Next week I'll be buying a fuel pressure regulator and plenum gasket and getting those replaced. Should be fun.....
I'll get this figured out at some point.
