i know i have asked this before but....what do you do with "old" gas. i have an outboard that won't start and the first thing i will be asked is "the gas in the tank fresh?"
Pour some "seafoam" in the tank and shake it up. Otherwise, drain the gas and use it for the charcoal grille. Put new gasoline in the tank and remember to mix some "seafoam" in with the last fill-up next time before storage.
seafoam or stabil is a good idea ,putting it on your charcoal grill VERY BAD idea on so many diffrent levels,or you can mix it half and half with new gas and run it thru the lawn mower.
A fellow volunteer fireman used some old gas to burn the leaves at the station. Small explosion, third degree burns, and years of continual ribbing from us should keep him from doing it again...
Depending on your set-up, you could probably run it through your Scrambler. Half fill up with premium and a couple gallons of old gas should run right through... Provided you aren't fuel injected or anything...
