Options
chrisblair7
I have just started my scrambler search and have a few questions.
1. I read on this site that CJ-8's only came in I6(258) and I4's but I've seen some for sale with V8's(305 I think). Did they just do an engine swap with a CJ-7?
2. What do you get with the Golden Eagle, Laredo, Renegade, etc. options?
3. What should I expect to pay for a nice scrambler?
4. I've had a CJ-7 with the I6 and is the extra weight on the scrambler noticable or is the power comparable?
5. Is the AC worth getting on the scrambler? (On most CJ7's I've heard that it is barely noticeable)
Thank you for your help.
Welcome . I will address each question indivdually:
You are correct that Scrambler only came with 258ci straight six cylinder motors or 151 iron duke 4 cylinder motors. It is a popular swap to put a 304 V8 into them or a 350 GM motor.
The different packages had a wide variety of options. There was never a factory "Golden Eagle" Scrambler produced. Laredo Jeeps were the nicest made. They included looped carpet, a tach and clock, heavy guage"leather like" vinyl two tone seats, a leather dash grab bar, a leather wrapped steering wheel, chrome 8 spoke wheels, padded dash, swing away tire carrier, rear step bumper, Laredo decals, silver rocker moldings, fender flares, etc. The door panels for hard doors were different as well adding carpet and vinyl mix on all years except 1981. The Renegade package (also called an SR Sport) included high back seats, swing away tire carrier, custom stripes, padded dash, rear step bumper, fender flares, etc.. Base models could be ordered with a large assortment of options.
Tough question. You are in the right part of the US to find a rust free one. Prices vary widely- but for a good one expect to shell out anywhere from $6000 to $15000- depending if you want a restored one or not. There are a couple in the Auto Trader in South Texas for $7500 to $10000. You may want to consider if you want one that is modified or stock. Be honest with yourself on how mechanically inclined you are. If you do not mind turning wrenches you can spend a lot less.
The 6 cylinder in my opinion is powerful enough to move a Scrambler effectively. If you are going to off road it heavily, modify it significantly, or want a speed demon than you may want a v8. The 6 will do the job in most instances.
If you like cold knees than the AC is great. It is exactly the same setup as a CJ7. You will be looking at a lot of hot days in Austin and a lot of traffic- some AC is better than none.
Best of luck on your search for your new Scrambler.
Kyle
Good luck in your search. It looks like you are starting out the right way by doing research.
A couple of notes-
The 304 was an option listed for the '81 - 7's and maybe '8s. I know- I had a new 81 and wanted to get one w/ the 304. My dealer didn't know squat and said the weren't made. Then about 2 months later another guy I know got one, new.
I think they only made them early in fall 80- thru early 81. Kinda rare. It is a bolt in switch, but if you are looking for a good transplant, I think a lot on this board will vote for a good 95 or newer 4.0. 190 hp vs 115 (new rating for a 258)- Reasonable mileage and readily available parts.
Beware in your search for guys how do cosmetic only restorations and the hiding of "flaws". Jeeps require maintanence and they can rust, etc. Don't jump at the first you see. Good ones are out there and they don't have to be the really high dollar rigs that scream " I am expensive so I must be in really good shape"-
Patience, Patience and then more Patience.
There, you have my advice and you can value it for what it cost you if you want!
1. Hemi!! 360, 401, 304, LS1s... all kinds of swaps. Big engine bays and a crazy huge aftermarket make almost anything possible. Keep in mind that a swap is only as good as the parts and labor that go into it. If it's a hack job, you could end up with all kinds of issues and since it's not factory it can be a mess. A well done swap can be great though.
2. Can't help, I know a clock, tach and leather grab bar came on the Laredo though! :D
3. what the others said.
4. personal preference, most are fine with the 6.
5. No, way more trouble than it's worth unless it's fresh off a rebuild or new aftermarket. Take the top off :D
