999 in a 5
I just went out in the shed, and mearsued a 999,and a T-176,the 999 with the dana 300 adapter is 3 inches longer than the T-176 with dana 300 adapter and bellhousing,and the dana 300 is 1 inch longer than a Dana 20.But if you get the short Dana 300,I don't remember how much shorter it is than the long 300,I think it's like 1 1/2 inches or so.The T-5 and T-4,with bellhousing and adapter,are 1 inch shorter than the 999.But from what I can find,as far as CJ-5's go,the T-4 or T- 5 only came behind 4 cylinder engines.I have a Turbo 400 and Dana 20 in my 5,I have a CV joint in the driveshaft,but I also used a Chevy V-6,and the bellhousing to block parting line,is about 4 inches in front of the firewall.It should work,seeing how a 999 and 300, are only 3 inches longer than a T-176 and dana 300,and if you get the shorter 300,that would help even more.You can also drop the skidplate down,and or use a CV joint in the driveshaft.You probally will have to modify the skidplate to fit a Dana 300.
