OT....Help
fisherman
Whew, was that you?
brunswick
md
We took our 15 pass van in for a tune up Fri. they replaced the plugs,wires, cap,rotor,PCV valve and an oil change. i pick the van up and ran around fri nite and alittle on Sat. then packed it up to go on our family vacation/pick up new jeep motor trip. Start the van, load all the kids up,get coffee, get JP mag for the ride and wife puts van in D and it.....dies :eek: Start it back up,idles fine put it in D....dies
The only other thing i did was run the Batt. down while i was working on the trailer lights last nite...hooked up batt. charger and it was charged by morning. Anyone have any ideas? BTW it's a 97 Dodge Ram 3500.
i'm very happy it didn't happen on the PA turnpike with a van full of kids :eek: or on my way to Jeepskate's to pick the motor up :rolleyes:
Chris It could be the battery................alot of the new models have to have a constant voltage of around 10.5 to 11.5 plus volts for the computer to operate right,it could be that you may have killed one or more of the cells when you drain the battery down also it may have caused the computer to reset to the default mode or limp mode which you will need to unhook the battery (make sure it's a good battery) let it set for about 30 mins.........hook the battery back up and start it then let it run for abut 15 mins so the computer can re-learn the motor settings..............hope this helps-JC
Mules,
Thanks for the input but it didn't work. i went out and got a new batt and cleaned the connectors let her run and everything's a go untill i put it in gear and....dead. Oh well i guess thats why the pros get the big bucks :cool:
sorry
Let me know what you find................my Jeep did the same thing a few years back and it was the battery.....................after i put a new one in it was fine.....................1st thing i thought of............ :confused:
Does it feel like the vehicle tries to move when you put it in gear? Some dodges and a few chevy's had some problems with the lockup torque converter sticking and would kill the engine the second it was put in gear. ?????
Mike,
Thats what the guy at the shop said. He thought i might have blown a fuse while messing the the trailer lights, so before i had it towed i checked all the fuses and they look good so its at the shop now. Thanks!
Good call Mike, the selinoid for the torque converter lockup is shorted. They have it on the lift waiting for the part :) This is just another reason for me to keep the standard shift in my jeep! Sooo much simpler!
