OT: Magnetic pipe tape
TXtrailbuggy
It sure is smokey in here
Kyle
Okay folks, here is what I am looking for:
Magnetic tape that you place around a pipe to draw a mark for a squared cut. Not sure if anyone makes something like that or if I just have to buy some magnetic tape and make my own.
Thanks, Bo
Hmm...never seen it magnetic, I have "tubemiter" on my computer and just print, cut, and tape. But a magnetic strip for straight cuts sounds like a great idea!
I have only seen it once, a welder at a place I used to work years ago used it to cut 30" pipe. I need it to make cut on 24"+ propane tanks.
What I have done for years when cutting large diameter conduit is use a standard retractable tape measure.
Wrap the tape "backwards" (the numbers against the tank) around the tank until the tape meets back up with it self.
The tape will conform to the tank and lay flat while giving you a straight edge to mark.
The wider the tape the better results, also the larger diameter cylinder you are circumscribing the better.
With the size cylinder you are planning on doing a 1" wide tape measure should work fine.
I have seen magnetic templates as well, but only remember them being for miter cuts.
HTH
I have tried that before and it works great for scribing. What I also would need the magnet for is a guide for a plasma cutter. I usully use a thin peice of gauge metal and conform it to the tank or pipe that I am cutting, the magnets would just work faster.
