OT - Marine TBI
kohldad
Goose Creek
SC
Hoping someone can at least put me in the right direction here. My father has owned for since almost new a 1969 Thunderbird Cabin Cruiser 23' (Same boat as was on Flipper except 2' longer). However, the original owner went against the salesman's advice and purchased the boat with a single screw because he wanted the Ford 289 manufactured by Holmon & Moody which at the time was a precision balanced Race Car engine. This leaves the boat under powered causing top end speed to be just where the boat is starting to plane off. :(
After 38 years, we are finally tired of fixing points every spring and want to move up to an HEI system. The HEI system is easy as we can simply by a complete one on ebay. The problem is my father is also tired of the MC2100 carb and wants to go to a TBI system. While there are tons of information on the TBI for automotive application, the marine application is being harder to find out any information on. Figure between the HEI and TBI, the performance will be a lot better.
Any suggestions on source for marine TBI conversions? Or will any regular automotive TBI work since nothing goes in the exhaust?
For a TBI, you'll need an O2 sensor in the exhaust pipe. Call Howell and see if they make a system for it or can tell you what to do. Then, there's always the junkyard TBI conversion. I don't know Ford engines much, can you take a FI system off of a 302 and bolt it on there. should be cheap out of a jy?
The open loop Holley kit used nothing in the exhaust and seemed to work fine in my CJ5, you won't have to adjust for altitude anyway. howell may be able to better answer your questions though, or the megasquirt boards, they may have some info
