OT: YJ/TJ tailgate question
1x1_Speed_Craig
Simplify...
Greeneville
TN
Because a couple of the other boards have proven less than helpful (no responses, or cocky responses), I thought I'd post this here.
Has anyone swapped a TJ tailgate onto a YJ? I know the holes on the body for the hinges are spaced differently, but what about the door? I heard somewhere that they were compatible. The parts catalogs list a different part # for '87-'95 YJs and '97+ TJs (for the door itself). A local salvage yard has a PERFECT TJ tailgate in black (matches my YJ), complete with spare tire carrier, 3rd brake light, hinges, etc. for $125. YJs are getting old enough that the Michigan salt has often taken its toll on used replacement tailgates (including my current one).
I'm going to stop by the salvage yard and take some measurements (YJ vs. TJ) to compare, but thought someone here might be able to enlighten me.
Help!
Thanks,
Craig
Thanks Matt.
FWIW, I stopped at a salvage yard tonight and took measurements on TJ and YJ tailgates. The upper hinge is positioned 1/2" lower on a TJ, so it's not compatible (unless you redrilled the mounting holes in the tub).
Craig
