Paging all dana 300 guru's
scott anderson
Old age Mutant Ninjaneer
Paragould
ar
ok..here is the deal..i got a deal on a ford dana 60...that means atlas II @ $2k or flip kit for $550. OR...here it comes...
What would keep a fella from installing a cable shifter, flipping the sucka, and move the vent to the access cover and be done....i may be missing something, but couldnt a guy flip a dana 300 for the cost of a cable shifter...Tell me where i am going wrong..i was going to post on pirate but they would have flamed me to death...you guys are too nice for that..:D
looks like i might have to make a custom shifter bracket for the cable shifter..the stock would be in the way of the driveshaft...seems like someone on here did a flip...who was it
I think I saw a flipped 300 in a YJ project, and the guy made a shifter bracket off the side of the trans. Still shifts the same way, except the levers are flipped left-to-right too, and you have to work out a separate linkage system.
I am thinking it can be done..like you say ...a little creativity on the bracket...and use the other end of the shifter rods. Cable shift would just make it easier
Come on guys...i was sure someone on here had done the flip...but i cant find it in the archives.
I'm also interested in this - would open up quite a few options for axles and a larger front driveshaft for me.
Relocating the vent is easy. What about the seals on the shift rods? Will they hold well enough?
You would probably need to drill and tap a new drain and fill plug but that's no big deal.
I am going to do this myself...i refuse to pay $550 ...i will get this figured out and i will post the write up.
I studied on this last night...i think i can use the other end of the shift rods..that have the little caps on them....and attach the cable shifters to that...as my other thread states...i am going to put in a np241 until i can get this project done.
I take it since you are concerned with drive shaft clearance, u must have a similar setup as mine and are limited by the tranny pan?
Right on!
You go brother!
Heck yeah!
Git er done!
(posting to get updates to this thread incase it ends up being a fun-to-watch nightmare :D)
Seriously, assuming the thing won't leak like a seive when you flip it, I don't see why this couldn't work.
Search on Pirate (you can use Google to do it) and you should find plenty of info and pics on DIY flips...
Yup I have a 4L60e/ D300 witht he Novak adapter. Driveshaft clearance is a little tight.
I've seen the DIY flip - but if it's just a matter of flipping and sticking a cable shifter on it would much cleaner in my opinion. Clock it up and put a skid pan under it to protect everything and there should be no worries about breaking anything off.
Like Rodney said, it has been done to death on Pirate.
Your big problems will be the front driveshaft, and having all your shifter stuff located near your lowest point of your rig. Cable shifters aren't too cheap, either- you would be better off fabricating shift levers IMHO.
i did the google search for the pirate threads...i found a bunch of threads but they either used the down east kit $550 or basically fabricated the same thing....i think there has to be an easier way....cable shifters arent cheap if you buy them..but i have an old spicer 18 twin stick shifter and the cables themselves are not too bad...if i had to pay to have it done i would agree, but i have my own machine shop, and my labor is free, cause it is my hobby.
Cables aren't that expensive if you shop around. I poked around Ebay for a couple of months and scored heavier duty stuff than what comes with the commercial kits for much cheaper. Just have to fab the sticks and buy some clevises. I got two 'generic' push pull cables and one from some military application and paid around $10-15 apiece.
My main issue isn't cost as much as durability- I have had cable shfters fail before, and you would have them right at your breakover, in the mud/water/etc. and also near your exhaust. They get pricey the more often you have to replace them, and a cable isn't fixable in the field with a Ready Welder like a pair of levers would be.
Aluminum D300 DS and PS drop case
Saw over on Pirate, a deal where Stak is supposedly going to make a case for the D300s that is either driver side or passenger side drop - your choice. For somewhere around $600 ish.
Might not be a bad option. It should take almost all aftermarket stuff too.
i ended up getting a pass drop dana 60 ..so i dont need to flip the case now...so i will shelve this idea until necessity breeds inovation..:cool:
Tom -
Fire up google and type in search terms, then "site:pirate4x4.com/forum"
Like this:
dana 300 site:pirate4x4.com/forum
edit - don't know why the forum is blocking the text - it should read "site<colon>pirate4x4.com/forum"
Works for all sites, and it's a great tool..
Roger
4wdjeep.com
Guess I was busier when this thread came up the first time. We flipped a d300 and put it in my brother's yj. It's very easy. We put a breather in the new top, plugged the old breather, and bent some shifters that sneaked around the driveshaft. No problems with oil leakage.
