- Corvallis
- OR
Got myself a short block 304 and a set of heads. Not sure exactly what I have but casting number on the block is 3185527 and has 304 stamped in teh side. Heads have had some work done. there 360 heads, 3231475-2, there is a sheet of paper in the port that says 1971 304 heads, custom flow job by Hutch in Stayton, SBC Valves, Edelbrock Springs / Keepers New Bronze guides. They have dual springs on them and are set up for screw in rocker studs. Chambers have been pollished as well as exhaust ports. Looks like these heads were run on this 304 but I don't see any clearencing for the larger valves in the block???
I have no idea what cam the block has in it or if it's been bored or really has a 304 crank and rods. But the pistons have a dish to them and four valve reliefs each.
The other engine is a 75 360 with about 70K on the clock. It's complete pan to pan with all accesories on the front end. Looks like it was just pulled.
Not sure which way I'm going with this stuff but I think I have my V8.
Got all this for $475
