pics of my 8
scrambeled
y is the hood always up??
hammonton
nj
well actually not mine but my wifes.still has a little bit to go to get things right.with the help of a few people today on the boards here i was able to find the reverse light wires ive been searching for. i wish i would have taken some before and after shots.heres kinda what i did to it when i got it home.
front warn winch plate
warn rock bumper and hoop
hurst quarter stick shifter, and a hurst shifter scavanged out of my 77 tans am for the tansfer case
3 point harnesses by corbou
and alot of other goodies like gauges and a radio for the old ladie.
and a 1 inch body lift to replace the 2x4's it was sitting on.all of the body mounts we shot and most of the frame mounts.its still loaded with rust on the under side witch in the spring ill fix with a fiber glass body,or if i find a clean steal tub.okay now with your opinions,was it worth 4500$ without the stuff i put on?
forum
forum
forum
I think it looks great. I love the pics, Big Walton will be proud..:D
Truck
i know something was up with it.i bought a replace ment set from 4 wheel drive hard ware and it still didnt look right ill try switching it back.theres still alot of rust starting to pop through here and there,and the frames got a few weak spots arounf the tranny case crossmember.the back part of the frame has been boxed in,in a so-so way.alot of small plates that were peiced together.still along way to go in my eyes to get it 'right'
need to get some gears for it.theres 3.31's in it and it just dont want to put the power to the ground as it should.when its in four low,its a fun ride.it has a np203 full time transfer case so i dont have much of a choice,either high or low rage.to me the trucks a '20 footer' but it is a solid foundation of what me and the wife wants to do with it.thanks for the kind remarks
scott
Dash/Interior color
Can you, or anybody else tell me the color of your door panels and dash?
thanks
I looked real hard at buying that scrambler when it was for sale across from 84 lumber in Court House. Me and Mike Werner talked about picking it up for resale! The frame scared me so we backed out! If you need a little help let me know! I'm in North Cape May area! It will make a nice rig but that frame needs addressing. Nothing a little welding and patching won't fix though! Did you fix those wooden body mount (2x4's). LOL! Good Luck! Kurt
And if you need a frame, I have one for sale. See classified section.
Truck
just finshed up the body mounts today,actually.the frame was a little half assed boxed in but i added some steel to it to rigid it up.as you know Rubberhook,it wasnt much to look at when it was for sale,nor did it run to good.i got rid of that electric fan,and skinny radiator,and put in a 4 core conversion.it runs like a differant beast now.im actually looking to get a frame from california,the shipping to the east is a bit high but is a good foundation to start new,and not have to clean up any body elses messes.and i have been doing that since i brought this home.thanks for the replies,it does get alot of rubberneckers driving by.
You still have the elect fan? That was a duel 1 and new if i remember right. That would be good for you Truck for your upcoming swap! We could also get your frame up here fairly easy! Mikes coming up to my place tonight even! I'll also be making some trips to Johns house to work on the Scrambler Project! Sounds like a deal brewing?
you are correct,it was a deul one from flexolite,with the relay-temp swtch.i may keep a hold of it as an aux.fan but who knows.i need alot of little stuff (as in my wanted ad) so i might try to barder it.i like trading suff:D
as for a frame id realy like to get a roller to swap gears and do any nessary repairs then just switch bodies(im trying to talk the old lady in to a new tub so in the end well have 2 scramblers.thats her goal.his and hers
That is quite a woman, you better hold on to her;)
