Pile of Parts - Free to New Home
FLCJ8
Palm Bay
I'm cleaning up for our move and figured I would check to see if anyone has a use for some of these parts before they go to scrap.
I had discovered that some items I had tossed out were actually sought after so I wanted to avoid that situation again.
FROM CJ5 (unsure of year, PO converted to 4 wheel disc)
1 set of 11" front backing plates and drums
1 set of 11" rear backing plates and drums
Rear fixed bench seat Honey(?) color (frame appears rusted as mounts are loose)
Has a tear in the corner of the top, not sure if someone may want the cover for some recovering project
(I'll post a pic, if anyone has an interest, once I remove some other items.
FROM '83 CJ8
1 set of 10" rear backing plates and drums
1 set 5 bolt front hubs
1 set 5 bolt OEM lockers
2 sets 2.73 carriers and R&P gears
3 rear OEM two piece axle hubs
All these parts were functional when removed for upgrading.
The parts are located in central FL (32950) and most would need to be picked up due to weight
I would be interested in some of the CJ8 items, I’m hoping to be right there in June or early July for the launch of the worlds largest rocket ever built. Maybe the seat also
We are just south of there.
We'll be in N. Georgia by then but I could probably make arrangements for pickup at my brother's place.
Ok sounds good. I will PM you my info contact. Could you post up pictures of the bench seat ?
