powder coat
I haven't done it myself, but after reading responses from other boards where folks have used them, the results are amazing. I plan to do it soon...
Ive heard alot about people doing it with guns. It works well, but I think its a little bit of a hassle to get it all set up and working properly. Apparently it takes some experimentation to get good results.
Claw- powder coating IS done with a gun. Scott -the cheap guns work exactly the same as the big dollar guns . I have an extra oven and that is the limiting factor. ( SIZE OF THE OVEN) otherwise results are the same as long as you realise first that to get good powdercoat results you have to sand or bead blast all parts first.
Scott, as Tim stated, results are the same as the commercial outfits. I have an old kitchen oven in my shop and have built a stand to support the oven racks so that I can coat the parts outside. After coating, I can carefully slide the rack (with the coated part suspended) into the preheated oven. The key is sand or bead blasting and the part has to be perfectly clean and oil free. It's much easier to handle the parts with latex gloves after blasting than to try to clean the rough part surface.
scott anderson said:
thanks ..i think that the limiting factor seems to be the size of the oven you have..
If there was EVER one person that I would think could overcome that little issue, you'd be it...
Just throw something together from an old tanker truck, a couple of furnaces and a thermostat and you'll be doing frames in no time :rotfl:
