Power Steering fluid Leak
I would like nothing more that to buy you chaps an ice cold beverage right now, your brilliant.
So both adaptors do come of the box, and both ends of both fluid lines fit both ports.
They are to long though, they do tighten down all the way and I cannot remember if they were flush on the old steering box?Should this be an issue if the do not tighten down all the way??
FLCJ8 - You mentioned the O-rings. Are you talking about the O-ring at the very end of the fluid line? If so I have not replaced them, If you think I should then I will.
That looks better. You should always replace the o-rings when working on those lines (think they cost .50). Tighten them enough to prevent leaks but no more than that (too tight will destroy the fitting).
I will get fresh O-rings tomorrow. Thank you for you help.
I will work on the rest of the assembly this week.
Wayne.
I got a little ahead of myself with the power steering lines. I ended up removing them because it is a lot easier to turn the spline on the steering box.
So i started working on the Jeep again this morning. Set my marks on the spline and the steering box. Went to turn if the 3 - 3 1/2 revolutions so that I can turn it back 1.75 times and attache the pitman arm etc
Well the spline only turn 1 & 1/2 turns. Would you say that this new box is no good?
Different ratio?
Sent from my SM-G900V
Its 1 1/2 turns lock to lock??? Is the output shaft moving the full amount required to make your pitman arm go the full range in that 1 1/2 turns?
So I googled the turning ratio on the box and from lock to lock is 3.4 (as you all know). I was getting 1 1/2 turns lock to lock.
I called the company I got it from and there are no more boxes out there. They said just send it back and we will re-imburse you. The more I thought about It I figured the box has a fault.
For giggles I installed the box again and turning it again, and what is happening is it is sticking/stopping at 1 1/2 turns but If I apply pressure and keep turning it I can get there 3.4 turns lock to lock. (So it has a flat spot) since these are boxes are hard to find I am going to take the gamble and move forward with the installation and see if it works itself out, this probably is not the smartest thing to do…but well see.
I am going to try and locate someone down here in SWFL and see if they can rebuild it if it ends up needed it again. At least I have the box.
I just wanted to say thank you very much for everyones help with the steering box swap.
Everything is done, she drives like a champ.
Thanks again.
Be lucky,
Wayne.
No issues with the binding spot?
Not that I have noticed, she feels great.
I am looking for some new tires so I have not had a good road run, she feel good driving around town though.
Thanks
