Yes. the notch in your spline should be close to wheels straight also. You can adjust drag link to center wheel if it is off a little. Be aware of the inner threads on drag link so you don't get to close to the end. If it were to come out, bad things could happen. Double check torque on all bolts when done as final step.![]()
Toby:
Can you confirm what you mean by (the notch in your spline should be close to wheels straight also).
I appreciate it and good advice on the drag link..Thanks.
