Power Steering fluid Leak
I believe I have made a ROOKIE mistake.
When you center the the spine in the steering box.
Do you do it with the wheels on the ground and no pitman arm attached?
Or wheels off the ground and pitman arm attached?
Yes wheels on the ground and pointing straight ahead. For centering the gear, the Pitman arm doesn't really need to be connected until you are doing your fine adjustment to the drag-link (I'd probably go ahead and connect it anyway so you know don't accidentally rotate the gear while installing the pitman).
Thank you Sir - this is what happened.
I used the notch on the spine where the set screw goes on the steering arm as a marker.
I turned the spine with the wheels on the ground and no pitman arm attached and got 3 ½ on the spine. I got on the interweb and confirmed that the H1 box does turn 3 ½ times so I turned it back 1.75 turns to center it, the notch on the spine is facing up.
Then I attached the pitman arm and as you know the pitman are only goes on one way because of the grooves.
I was about to attach the end of the steering arm to the spine on the steering box and noticed the notch had moved (no big deal – I know I subconsciously moved it when I added the pitman arm).
So I jacked the front end of the Jeep up to get the front wheels of the ground.
I then turned the spine on the box again and this time only got 2 ½ turns, so I turned the spine back to center it 1.25 times and the wheels are still turned to the right (not drastically but enough to put your tools down and scratch ya head).
So I am trying to figure out what I have done wrong. o
Obviously I would like to sought this issue out prior to adding the steering column and power steering fluid.
Thank you.
I have been mulling this over.
If I find the middle of the spline on the steering box then add the pit man after, then adjust the drag where it fits the the smaller end of the pitman arm I should be ok as long as the wheels are straight from the start....
Wayne
I'd start over and maybe this time use a paint pen to make alignment marks on the spline shaft and gear box housing when you have the gearbox centered. That way you can reposition it pretty easy if you move it while wrenching. Using the flat spot is a pretty vague reference point and you want to be more precise (make a fine line with a paint pen or scratch awl).
10 4 will try that again and try to be more precise.
Question - Once the steering box is centered should I be able to get the same amount of turns with the pitman arm on and attached to the steering rod?
Yes. the notch in your spline should be close to wheels straight also. You can adjust drag link to center wheel if it is off a little. Be aware of the inner threads on drag link so you don't get to close to the end. If it were to come out, bad things could happen. Double check torque on all bolts when done as final step. :thumbsup:
Toby:
Can you confirm what you mean by (the notch in your spline should be close to wheels straight also).
I appreciate it and good advice on the drag link..Thanks.
With your wheels straight and your steering gear centered, the alignment slot on your splined shaft should line up closely with the Pitman arm splines. I can get a picture for you if you would like.
Toby :wave:
Toby:
If you have a photos that would be sweet.
I am back on the job today.
I put some tape over the end go the spline on the steering box to protect it - with wheels on the ground I turned the shaft all the way to the left - I guess I am confused as to where to make my mark in order to turn the shaft to the middle.
Thanks.
I am wondering if I am using the wrong mark.
I was working of the notch where I believe the set screw goes from the steering box. I noticed that there is a tiny drill hole on the shaft that is actually facing the inside frame on the drivers side (there shaft is all the way to the left) should I be using this hole as my mark)
Kinda funny after all the work i have done - I thought aligning the wheels would be the easiest.
Thanks.
It doesn't matter what point you use on the shaft (although I would pick a spot that will be easy to see as you re assemble).
Just make sure the gear is centered when you make the mark (as described a couple times before), and then make sure the marks are aligned after you attach/adjust the pitman and drag link. And again when you attach the steering shaft. Don't over think it, it's really a simple concept.
Thanks - your probably right, I am over thinking this.
I got my wife involved (she is smarter than me) did the measuring and did the marks. (Wheels are on the floor) totally had to adjust the drag link - there is zero thread showing on the drag link now
Attached the pitman arm and sure enough mark on the shaft moved to the right nearly 1/2"
Hi:
Just a quickie. Has anyone ever had an issue with Summit Racing, out of curiosity?
A few weeks ago when I was putting in the H1 steering box in the Jeep, I noticed that the splines on the box were rounded on the ends, and the knuckle on the end of the steering shaft would not go over the splines.
I should have checked this out prior because the steering box was not well packed and there was a large hole in the shipping box when I received it. (stuff like this happens)
Anyway I was going to file the splines down and decided to do the proper thing and sent is back under warranty.
So I sent it back to Summit and they sent it to Cardone - which is cool and I was grateful.
But when things started to drag out i contacted Summit, they said Cardone shipped it to them I would get it soon, when I did not get it I called Summit again and someone different says Cardone still has it and it has not been shipped.
This is just one scenario out three different times the Summit has told me something and it did not happen ( I won't go into details)
I totally understand that things happen and may not happen on time. But I must admit I am surprised the way they are doing business... I am hoping to get the box next week, hopefully!!
Been buying from summit before internet. . Never had a problem . But there is a shortage of h1 boxes. So thats probably your problem. What i hear from cardone is everyone that bought there h1 boxes are returning a different core and they cant rebuild them. So now company's only send out a h1 when they get a h1 core back. I know as it took me a long time to find one. Summit was backordered for 2 months and i canceled.. good luck
Thanks, yeah I know how hard they are to get. I had a hard time finding the one I purchased and the truth is If it takes awhile to repair it, then it is what it is.
I was just disappointed that Summit was not more up front with me, instead of saying it was sent out and me getting excited and waiting for the part to show up, just tell me it was still on a work bench somewhere and you will get in in 2-4 weeks
Hopefully I will get it next week and get back on the road.
So I finally had to get my money back from Summit - very disappointed in the company.
So three months later I need to go back to shopping for a 96 H1 box and must admit I am gun shy about buying online.
Can anyone recommend somewhere else to order a H1 steering box. Has anyone ever done business with CarID?
Thanks.
Wayne.
Sorry to hear you're having trouble with Summit... I was just thinking to myself how good they are as I just received parts today that I ordered over the holiday weekend (with free ground shipping they basically delivered in 2 working days).
No experience with Car ID, I think I got one from Amazon once, and the other was from Oreily.
You know I am more aggrevated about there attitude more than anything else. At the end of the day, they are probably a good company and I just had a sour experience with them.
