Now onto the front brakes... I actually expected this to be a little easier, but, umm, nope
So, the plan is, run 3/4 ton rotors/calipers since we didn't have the origional calipers and they would have to be ground down to run a 15" wheel.
Here are the rotors, the one on the right is the dana60, and the one on the left is for an 8 lug dana 44
Here is the stock caliper bracket.
My origional plan was to make a whole new bracket, but due to the off set of the mounting flange at the spindle and where the caliper needed to sit, there was no way without a nice expensive C&C machine to make the brackets, so, plan B.
The plan was to modify the origional bracket for the calipers, and needless to say, it was VERY tricky. Not only to make the nec. parts but to figure out where to cut the origional bracket.
After some tricky welding, here is how they look
Now, the orional bracket is cast steel, so you need to preheat it just a tad, and I did tripple pass's and portions of the new bracket pieces are layered to maximize strength against the cast steel, all in all, I am very confident there will be no problems down the road.
