Prodject ZeroToWow
crash
Mad Scientist
Gold BAr
WA
The time frame to start the prodject has finally come.
The actual planning for the prodject started last year, with $$$ and parts slowly being collected...
Here is what I am using
The rig, 83 scrambler, all stock!
Chev 350(digital projection)-th400-203 doubler-205 t-case.
Front diff chev kingpin dana60(will be narrowing it)
Rear diff, corp 14 bolt
Springs, rubicon express 2" lift YJ springs(supposed to be very good anti wrap characteristics and flexy)
Tires 39.5x18 boggers mounted on beedlocks.
Here is how it looked after we drug it off the trailer, the thing had sat in a field for a few years.
Aint it cute
:D
First task, to get the burnt up inline 6, t-5 trans and dana300 ripped out of it.
What a mess, so a lil elbo grease, a thing of casteral superclean, and no more goo in the engine compartment
First task was to get the diffs cleaned up, the corp 14 bolt was under a club members rig for a # of years with link bar mounts/brackets that needed to be removed..
Little torch action, I had decided to leave the trussing, what a heavy pig that thing is too...
Sunday night I finally got an open spot in my shop, so it got drug over. First place I decided to start on was on the front. The dana 30 got cut out of there, and then continued to attack the frame..
The progress will be slow for the next week as I am trying to get a vortec swap finished up, but stay tuned..
Man that's a nice looking starting point for sitting in a field! Gonna be a brute wen it's done. I envy your progress! Mine is SLOW and about to become more so as it becomes immobile.
tr
Just wait till I get my teeth sunk into the prodject, should hopefully move right along.
crash, I am curious.... I noticed you removed the front frame cross member that the stock steering box mounts to.....what do you plan to replace the cross member with, and what are you going to use for a steering gear box?
I am curious, as I would like to replace both on my rig.....
thx.
Just keep your eyes on the thread cj8wheeler as those questions will be answered..
bummer... I am at that point right now with mine, and I can't decide what to do. I would like to replace that front factory cross member, but I need ideas on what to replace it with....
well, when you get the front of the frame finished, I wouldn't mind checking it out.... Goldbar is only a few minutes from me..
Todd
nice work... looks beefy. Got any pics on how you integrated the the support for the radiator/grill piece?
how thick is the steel that you welded inside and out on the frame? How many pieces are sandwiched together for the steering gear box support?
thx.
Todd
Ok, I decided to remove the grill assembly, as it gave me more access to the frame rails. The bumper is made from 2x3 1/4" thick steel, and the frame is plated with 1/4" and fish plated at the ends to keep from having verticle failures at the end of the plating...
The next step I decided to tackle was getting the dana 60 narrowed and set under the jeep since there are alot of factors that go around where the axle will sit..
One thing I did not want was a full width 69" housing, just plain too wide, I had a few options.
First was to narrow the housing to around 62", but that was going to cause issues, the most important, where the pinion was going to sit for clearance to the th400 oil pan. Another thing about going with 62" was the fact I would have to narrow both sides of the housing, and then deal with the whole axle shaft issue..
The second option, narrow the long side 4", which would let me retain stock spring width and let me use the stock cast in spring pad, and thus letting me keep the pinion as close to the spring as possable. SO, I decided to go with 65".
First task, remove the long side inner knucle, and let me tell you, I thought the d44 inners were a POS to remove, :mad:
Started by cutting into the weld, then working into the weld with a grinder and dremel bit
Once the knucle was removed(3 lb hammer, I am still sore), I was going to be nice to myself, and used my verticle band saw to cut 4" off the tube.
Once the tube was cut I pounded the knucle on for now, and I will rotate both sides to set the caster when I get to that point.
Much better
I built front spring buckets, added 1/2" to the spring perch on the long side to match the cast side, and set the rubicon express YJ springs on the rig so now its time to get the housing sitting perfectly so I can tack the perch's.
So, once the housing is centered, its time to start getting the motor ready to jig up and build motor mounts....
here is the donor chev 350..
The motor had a coating of oil on it coming from a leaking intake, so I removed the intake to #1 reseal it and #2 take a peek in the valley to see just how new the motor was, and it was spotless.
All cleaned up and ready to use
Here is the rest of the drivetrain all bolted together and on my tranny jack, and my gosh, its a heavy setup
forum
Next step, get the wieght of the rig onto the springs, so the housing got centered and the buckets tacked into place.
Then the trans/ motor got put together in the rig and measurements started.
Due to the wide pan on the th400, the motor/trans got setup to 1 1/4" to the drivers side.
SO now that I got my measurements, I decided to plate a portion of the frame with 3/16.
And now it was time to build the motor mounts..
