Project taking a new turn
2K1TJ
Still Scramblin'
Rockmart
GA
After talking to my friend at the body shop, he has talked me into getting a new tub instead of repairing the rust on my current one.
I'm leaning towards fiberglass, mainly because of funds, because it'll just be a d.d.
Any tricks that are fiberglass tub-specific when it comes to installing a f.g. tub? Do I need that instalation kit that comes seperately? What's in it?
Will my bulkhead fit, or does it come with a new one?
What is a decent price for doing a tub swap and a paint job? He is a friend so he will give me a slight discount. For reference, he charged me $800 labor and materials to paint my TJ.
Who has the best FG tub? Best price?
I ended up getting a 4WD Hardware fiberglass tub. Mine will also be a warm weather DD (~80% road/20%off-road driving). I won't tout that "4WDH is the greatest...you must get one!!!". I'm sure there are other good manufacturers out there (e.g. - A.J.'s), but a local 4WD/Jeep specialty shop has been selling 4WD Hardware tubs for about 2 decades. They're very knowledgeable there, and I was happy to give them my business. Price was $1750 + tax for the tub, but I didn't have to pay shipping from 4WDH :D
Actually, it should be delivered to me either today or tomorrow. It's already at their shop.
I think $800 for a professional paint job sounds reasonable if it was a high-quality job. I'm going back and forth on whether to give mine a cheap-but-decent-looking paint job, or a professional-but-more-expensive one. My brother-in-law has a couple really nice spray guns, but his shop is 4 1/2 hours north. Still, I may have him shoot it for me after I do all the prep work. You'll have to sand out the orange peel on the fiberglass. I'm not sure what additional considerations there are - I'll ask more questions of the shop where I bought it after I get it mounted up and closer to paint.
On the install kit, you can get it as a package, but the place I got my tub is just going to give me an assembled list of items that I can get anywhere.
Good luck.
Craig
Keep in mind the limitations you're putting on yourself as far as tops go. If you never want to have a full hard top you're ok, but most won't work with that tub. Just FYI as something to think about.
When I talked with 4WD Hardware, they said a full hardtop would work with their tub. Of course, this statement wouldn't exactly be from an objective source.
Craig
If you do end up goig fiberglass make sure you do a good epoxy sealent on it before painting. Just a tip a fellow Vette owner gave me on painting my 1968 vette. It kind of works as a extra primer from what he was saying. Gives a longer life to the paint job.
I will probably never get a full hard top so that's not a huge concern for me, but it's something to think about.
Tom, I didn't know that about the sealant. I'll ask my body guy and see if he's familiar with it.
Thanks guys.
I did a 4WD drive fiberglass body swap (tub, fenders, hood) ten years ago. Unfortunately I didn't own the vehicle very long after finishing it. So, I can't vouch for durability and such. Added a full soft top -- no problems there. (Aside. I also added a rear heater from a 1989 Suburban. That was a great unit. Mounted it in back and ran heater hoses to it. Made my neck sweat in sub zero weather.)
My biggest surprise was the condition of my frame. I knew there were a couple of holes (It was from Michigan and all). But, I found that I needed a week of frame prep before I could bolt on the body. The biggest surprise was that the body mounting points were rotted through. You might want to ask your friend what they are gong to do to prep the frame. Might not be an issue with a Georgia Jeep, then again I wouldn't expect a Georgia Jeep to have any rust at all.
Second -- a tip that worked for me. I took a sawz-all and cut the body tub width-wise in half -- right at the leading edge of the door opening. I stuck that part in the corner and sent the rest to the dump. That left everything in tact so I could make templates and I didn't have to take copious notes on where everything went when. It made it simple to reassemble my new rig and also freed up room in my garage -- which you'll need lots of.
I really liked the way the fiberglass Scrambler drove. Then again, I replaced the suspension at the same time -- so who knows? Not sure what the weight difference is between fiberglass and steel is but it seemed like the COG was lower when I finished.
Have fun!
Craig,
Did you get the "deluxe" 4wd tub or the regular tub?
Mine will also be my summer/early fall daily driver. Let my beloved YJ take the salt and rust ( that reminds me when the scrambler comes out for summer play I have to do some serious maintenance/mild mods on the YJ)
Depending on the level of rust it may be a good idea just to spring for a tub, bodywork is painful, expensive (even sandpaper, metal patch, and filler add up).
However, if you cannot do the tub swap yourself it may be very costly as contrary to popular believe a tub swap is NOT easy, and it is alot of work and fine tuning. I figure if they guy charges $800 plus materials to just prep and paint he will charge at least that to swap a tub.
Honestly, I dont think I would pay someone to swap a tub just to much money and you will learn alot doing it yourself.
That was $800 total, Jimbob, not $800 plus materials( I know, I'm splittin' hairs:p ).
Anyway, no more fiberglass for me, at least for now. I bought a steel tub off ebay last night for less than the FG tub I almost bought a few hours before. I'm glad I held out now!
Looks like the guy did a good job with the body work but I haven't seen it in person yet. It's already been sprayed with bedliner.
