Pyle Bluetooth Amp
orange150
Fairfax
VA
I just completed the install of this little amp and so far am super happy with it.
I wanted a radio solution that was only Bluetooth since all I listen to anymore is podcasts or music on Spotify. The only annoying part about the install is the volume knob is 15/16.
If you don't mind, who makes those vent / heater cables and how do you like them ? I don't remember seeing the brass ends before.
They’re from MTS. I just finished rebuilding my heater box in April.
So far so good! They feel nice and tight, but I’ve only used the vent one so far.
Probably Phosphate coated steel - same as you see on high tensile bolts. It protects against corrosion.
Either way they look good, do the ends (pull knobs) come off?
They don't as far as I can tell. I've not yanked on them though.
They look far better than the crappy Omix ones I used. I'll replace mine with MTS as they break... and they will.
Well I ordered up 1 cable Friday or Saturday and got it today. All my cables are original since I bought my Jeep new, except the cable I'm replacing. Probably replaced it 15-20 years ago, and was china junk from day 1. The part that anchored on the back side of the dash never functioned correctly. This one looks like that's not going to be a problem.
