question about pre before line-x
jeepinjosh
pell city
al
I removed the seats, bulkhead, console and all that stuff today. Wanting to get the inside taken care of before winter.
What amount of prep work is needed for the interior to be line-x'd. There is defnately some surface rust..some pitting, but
nothing super bad.
- I was thinking about using some of that rust remover-etcher, then some grinding, then a coat of por-15.
-Is all this work necessary?
-whats the easiest route?
Line-X
If you search Line-X and Technical application guide (you may have to try several different combinations), you will find a PDF produced by line-x that actually outlines how to prep the surface for line-x. It is pretty complete, and in my case gave me much more good technical information than my local line-x shop.
I soda blasted the whole body to bare metal. I figured at that point an acid watch primer, then an epoxy primer then line-x would be the most durable route, but the tech paper suggested that the only correct primer to go over was a urethane primer; I didn't want just urethane primer. I chose to go with what I hope is a more durable system, acid wash primer, epoxy primer, single stage paint; I then let them rough it up and treat it like a truck bed. I had at least 2 weeks of curing on the single stage before the linex went on.
nothing super bad.
