Rear Shock Mount Help
McCree
Terre Haute
IN
I'm rebuilding an 84 Scrambler from the ground up. I basically started with a bare frame and I'm now ready to reinstall the body after having it redone. One item that slipped my mind along the way was upper shock mounts and I figured I better get them installed before I set the tub back on. After some research I've ordered some Ford towers for the front but i don't know what to do with the rear. If nothing else I'll install factory rear mounts but I haven't been able to find enough info for them to say I even know what to order for stock. What does everyone else recommend for upper rear mounts? For what it's worth I'm running a SOA setup with Dana 44's front and rear. I have read about installing a crossmember and mounting the rear shocks on the crossmember towards the center of the vehicle. Opinions? What exactly is the advantage to this setup?
I am surprised no one has responded to this. I have no answer as I have not gotten this far yet, but hope someone will chime in.
Adding a cross member and center-ish mounting can be a good way to run a longer shock and slightly increase flexibility off road. The point of this mod started as an easier way to keep your shocks from acting like an early bumpstop on axle compression or a limiting strap for suspension drop.
The trade off is a slight reduction in roll/lean resistance in on road driving. Adjustable shocks and/or anti-roll bar can help offset this in Jeeps.
A better option is to make/buy some extended height rear mounts that allow outside mount of shock with a longer shock to match your suspension travel needs.
Full disclosure: I have not done this on my scrambler, only seen pictures of others ideas. But I had both inboard and outboard set ups at various times on an early Bronco I used to have and my comments/observations are based how that rig acted.
