I'm rebuilding an 84 Scrambler from the ground up. I basically started with a bare frame and I'm now ready to reinstall the body after having it redone. One item that slipped my mind along the way was upper shock mounts and I figured I better get them installed before I set the tub back on. After some research I've ordered some Ford towers for the front but i don't know what to do with the rear. If nothing else I'll install factory rear mounts but I haven't been able to find enough info for them to say I even know what to order for stock. What does everyone else recommend for upper rear mounts? For what it's worth I'm running a SOA setup with Dana 44's front and rear. I have read about installing a crossmember and mounting the rear shocks on the crossmember towards the center of the vehicle. Opinions? What exactly is the advantage to this setup?
