- Middle of No Where and Too Far From Any Where
- Tn
I'm going to try to attache the pics here-to mount the rears trim the fender flare mount to 1" and position the flare where you want it above the factory rib of the the bodys rear fender-it helps if you have an extra set of hands or a few c clamps to hold it-mark the mounting holes and remove the flare and drill your holes-you can use the factory mounting hardware-the only sheet metal that you will need to cut is the lower part of the tub to make them look right-you might try putting the left on the right and visa-versa-hope this helps-JC
