Reinstalling rear glass in 1/2 hardtop
scrambled eggs
chapin
sc
driver side seat slid too far back and pushed out glass from weatherstripping..was in mid travel so i took it and gasket out...now catching hell trying to get it back in...any tips for reinstallation?
does the gasket "unclip" like the side windows on a hardtop?
there should be a seam on the outside of the gasket in the center where the gasket will come apart.
plus you will need to put in a small rope and do a traditional glass installation with a gasket
got the seam and the small rope apart..in regards to a "clip" ..no clip that i ve seen...looks like just a groove in both sides of gasket for top and glass to fit in. should i put gasket on top 1st then slide glass in or gasket to glass then try and wedge in...looks like a bear and a bit*h trying to do by yourself.
Soak it in warm water with Dish Soap. Do your install in a heated garage. The warmer the rubber is, the easier it is to make it go in.
2 people really help with the install. One to hold glass and apply firm pressure to seat it. And one to pull the rope. Use a good strong rope with very little texture. The smoother it is the better it will slip. It needs to be big enough not to slit the rubber but small enough to slip out under the tab of the weatherstripping. Use something like 3/32" rope.
Might even want to soak that old stuff in some silicone or rubber restorer type coating to make it more pliable.
Good luck. If you break it call Matt and see about a new slider and gasket from him.
Carl
might need you to break it down for a amateur....the gasket currently is two slotted where top and glazing fits in..do i put warm soapy gasket on top and then slide glass in to best of ability...currently has a littel piece of connector rope at joint in gasket. scrambled eggs needs coaching....
Sorry. I have done a few of these.
Best way if the whole window is out is to remove the rubber from the glass and then immerse it in HOT soapy water in a bucket or something like that. What that does is to lube the rubber up so it is more flexible.
Basically you have an h channel. one side makes a u-shape around the glass and the other side makes a u shape around the fiberglass sides of the top. Trick is getting it all together at once. Easy part is to put good and lubed up rubber around the glass and seat that well. The second person or helper will hold the glass in position over the whole in the top. Usually from the outside but might be easier to pull rope from the outside. All depends on thickness of the rubber seal on each side. Go for the less side of rubber to pull the rope on.
Take that smooth rope that is about half the width of the slot in the rubber and run it in the channel starting at the mid bottom of the window and then bring it all the way around and overlap say 2-3 inches. This will give you a place to start pulling the lip of the seal over the edge of the opening in the top. It is important to center the window in the opening and provide constant pressure on the glass to keep it in the right spot and not crack the glass. Buy pulling that rope perpendicular to the plane of the glass it will pull that lip over the inside of the top surface and then will snap tight as the rope moves around the window. Be sure to keep one end of the rope in each hand or tie it to something to keep it from slipping in the channel. It is very easy to let it slip through the left hand while pulling with the right and then have to take the window back out and start all over.
Take you time and go slowly.
Here is a video of a un-install at 3 minutes and then a reinstall of a window at 12 minutes on an old pickup. Same basic idea for you in the top.
http://www.powerblocktv.com/episodes/TK2010-09
Watch that and see if you have a few more questions. Sometimes seeing is better than trying to explain in words.
Carl
He is using a plastic tool like what you use on door sides and such but this guy also uses the rope trick where needed.
Carl
