Resurrecting my Alaskan Postal
Davide
Tampa
I have begun the task of restoring my poor Alaskan CJ. I will attempt to make this thread an account of the project. The time horizon is two years.
I have finally found a rental storage place that will allow me to work on it. It should be there in July and the restoration will really pick up. Right now it is in a driveway, and I am toying with small projects that don't render it inoperable.
I should also let you all know that I HAVE NO IDEA WHAT I AM DOING! I have hardly any experience working on cars. For every hour I have worked on the car so far, I have probably spent two on the internet or in my workshop manual trying to figure it all out!
Step 1: FOAM REMOVAL (i.e. Worst job ever)
Keep the faith.
I would rank scraping foam as being up there as one of the worst jobs ever as well.
Keep the faith.
x2 I used a 5-way painter's tool with the leading edge sharpened up some with a grinder, that made it 100 times better/easier.
Disc Brake Conversion
I went ahead and decided to convert the rear drums to disc brakes. This is my first automotive project involving cutting and fabrication! Very exciting!!!
I found some threads on other websites, read them all, and put that info together for this project.
The Parts:
All Beck Arnley -
079-0367 - Rear Left Caliper With Pad 300ZX 1984 1985 1986
079-0368 - Rear Right Caliper With Pad 300ZX 1984 1985 1986
083-2288 - Brake Disc (x2)
The Plans:
Attached below
Before Pics:
I machined the brackets out on a milling machine, and I purchased a harbor junk powder coat gun...
Almost done - just a few things to hook up...
Those are on my "possibly" list...
I was thinking about putting a locker on the rear, and if I did that I would go with the one piece axles for sure.
More Powder Coating...
Before I am finished, I suspect every last piece of the thing will be powder coated :)
