Rust questions
TimmyTooTall
Well-known member
Member
Joshua
Tx
Good day. I went to look at an 81 today. The seller stated it has surface rust but nothing drastic. Ok sounds good lets go for a look. Well I pull the floor covers up and there's a dozen+ holes and much more than surface rust going on. I need some advice. I'm mechanically inclined but I've never worked on/restored an older vehicle and I have zero experience with body work. I was looking into this jeep as a multi year project with "surface rust" that would be addressed eventually. This more extensive rust has me asking how deep a rabbit hole is this going to be? Again I have zero body experience and this specific work would be shopped out. With that said I need opinions. What am I looking at?
Thank you!
There are options here… really need idea of long term goal and budget.
I would remove carpet as it traps moisture and likely started this, that’s what happened to mine below… also the driver side does looks like possible filler, could be photo and carpet backing impressions.
Next steps depends on goal and budget.
Lower budget, quick fix get wire brush for drill and removed easy stuff. Vacuum and wipe with acetone. Prep with rust converter, prime and color match spray then clear coat.
Higher budget and longer fix grind until find metal and depend on what is found weld patch panels, prime, color match and clear paint.
YouTube can be helpfully and let you decide level of effort so you can decide if you want to do and get some new cool tools or outsource. Good luck and keep us updated, with photos…
Here is example of my project underway…
123063B6-7185-4887-B644-5F03364BCA0B.jpeg17086B46-A226-4935-9864-8FF4EFA24047.jpeg440EE07C-6FEE-4AEF-A1E8-EE21877C3548.jpeg
So my rule of thumb is that whatever you are seeing on the surface, it travels down underneath and you don't really know until you peel it all back... so assume you need to replace everything and if you don't, that is a bonus.
The costs of a shop doing it are going to be pretty significant (if you can find one that will do it).
To me, that doesn't look that bad, but I have started with some very bad tubs.
That being said, the costs of replacement panels have been slowly rising...
New tub prices as well... again, if you can find them... and then that is a whole other thread worth of stories around what issues they have.
Generally speaking, there is no such thing as 'surface rust' on an 8. As Certifiable said above, it doesn't look terrible but it'll need patch panels in my opinion.
Thank you for your insight folks. A bit more info.
Short term goal, get it safe and capable of light wheeling with stock axles. Long term goal, not set in stone but upgraded axles/suspension/armor/paint ect. capable of Fins and Things, Hells Revenge, Poughkeepsie Gulch, Governers Basin ect. Short term goal is 1-2 years. Long term goal is 4+ years. Budget is flexible as if I am to do this I want to do it right and I'm willing to learn new tricks to do so.
Lets talk about the evolution of rust as it is. If I were to clean it up as rubclt stated the budget way and spent my initial time focused on getting the rest of it up to speed how would the rust progress if I were not to dive deep into it for 2 years if it's garage kept?
A few more pictures of the "surface rust".
Again, thanks folks.
Yea, your rust doesn't look quite as bad as mine. I've never done body work before and am learning as I go. If you do try it, I recommend the panels from Quadratec. They fit very well on mine. When you read up on how to weld the sheet metal, they all say to take your time and let it cool before doing too many spot welds. They mean it!!! It is a slow process, but it really isn't that hard. Just take your time and don't expect it to go fast. I had hoped to knock the floorboards out in a month, but that didn't happen (life gets in the way).
Here's a link to my project with some photos for comparison if you are interested:
Good luck!
Any pics of the outside? Also, how is the frame? Take a close look at the frame especially in the area right before it goes up and over the rear axle. Salt, slush, and everything else likes to get trapped there inside the frame and will make it rot.
The frame looks solid. I don't have any great pics of it but I didn't see anything drastic. It's been a Texas jeep it's whole life. The outside is pretty damn good. Only body damage is the left rear fender area.
Personally..if it was me and I wasn't going to do the work..I would take the pics to a shop to get a very ball park verbal estimate. It will help define your quest in quality/condition and a price range. The rig is very workable.
Unless you are building to sell, looks good. I would treat, patch, drive.
I agreed that original paint looks good on a jeep. Plus you can drive off road and not worry about banging or scratching paint
It's a solid rig. As long as there's no rust at the seat belt attachment point on the floor that's a "wire wheel and corroseal" job. Stop whats there, enjoy it and plan for the future.
Given your plans, truly a CLR, scott bright treatment on entire Jeep. Some rust will turn partially white, black… here is a good link…
Yup, I wish I could have started with something like that! Assuming it has a decent price I would absolutely go for it.
