Saturday Night Fun!
Robert Slone
Spring Hope
Last night on my way home from picking up my 14 yr old daughter from her boyfriend's house I rounded a corner onto Horne's Church Road and heard a rumble that sounded like something rolling around in the back of the Scrambler. But, there was nothing in the back to roll around so I reached down to turn down the volume of the radio so I could listen and that's when I felt some vibration and realized the rumbling noise was something in the rear end. I spotted a place to pull off the road just a few feet ahead where I could get completely off the pavement but before I could there was a loud bump and the backend dropped what felt like 2 feet and the car stopped right there. I looked out the window and saw my tire still attached to the axle shaft roll by. I looked out the windshield to see where my tire and axle where going and realized I was pretty much looking up hill. I stepped out to see the vehicle was sitting on the brake flange and it was red hot. And just then the gear oil poured out onto the red hot brake flange and sent up a cloud of smoking, steaming fog. So, there I was stopped dead in the road at 11:15 at night 15 miles from home with no way to move. Fortunately this happened right in front of the Silver Lake Volunteer Fire Department and they had had some sort of meeting which had just broken up and the Chief and his wife where just getting in their truck to leave. He helped me lift the tire and axle into the bed and at his suggestion I locked it into 4 wd and let the front driveshaft pull the vehicle about 15 - 20 feet where it was off the pavement. We figured the damage to the flange was already done from where it had dragged at least 50 feet before it stopped so moving it that short distance wasn't going to make it any worse. Then they gave us a ride home. Very nice of him since it was so late and 15 miles in the wrong direction for him!
Well, this morning I called a local garage with a tow truck and we just got back from hauling it to his shop. In the daylight he could see that the cause of it all was a broken bearing. The irony of that is that the bearings and seals were just replaced about 2 months ago. The axle is the AMC model 20 with 1 piece shafts installed by the PO. I had seen some oil on the inner side of the tires which was caused by leaking seals and bearings. So either they weren't installed very well or they were just crappy. Or could the 33" tires and 2 1/2" lift have something to do with it? Anyway, now it's in the garage instead of on the side of the road and they will start working on it tomorrow.
I just regard myself as being very lucky that the gear oil on the red hot brake flange did not result in a major fire. Geat way to spend an evening!!!
Robert,
Maybe this should be a subtle warning to have at least a small exinguisher in the Jeep at all times. It deos not cost much but could save you a lot of hastle if you catch it in time.
Sorry about the axle. I had the same thing happen in my CJ-7 down in Atlanta after I had the ring gears redone. Got about 5 days on the gear change then on the way out of town I had the bearing go bad. I was stuck on the north side of town in a hotel waiting 3 days for a FedEx with a new set of bearings and seals. This was 13 years ago and overnight service was not such a big thing then, You actually had to wait for most stuff. After the new set however I got a good 4 years out of it.
No real joy to tell you, but just to check the bearing from time to time. hopefully there is no damage to the housing and you can just replace and go from there.
Carl
I used to keep an extinguisher in my truck, but haven't had one now for several years. Every time I see one in a hardware store I think about getting one. Now seems like a good time to do it.
I just read in the 4WD Hardware catalog that their 1 piece axle kit says " NOT RECOMMENDED FOR USE WITH TIRES LARGER THAN 31" DIAMETER". The Mosers and Superiors don't have the same warning. Would the manufacturer's name be stamped on them somewhere so I can try to identify them?
Sould I consider different axles? I have a T176 transmission and Dana 300 trans. case with Amc 20 rear axle w/1 piece shafts. When the 33 x 12.50 AT tires wear out I'm planning to go to 32" x 10.50 AT tires. Or should I consider new stronger shafts? What might be involved in a switch. 99% of my driving is on the road and this is (was) my daily driver. I've put about 12000 miles on it since I've had it.
Or is this just a fluke?
Probably just a fluke.
I know that the superiors have a horizontal diamond with a F inside. That comes from the company that makes their axles. I am not too sure about the mosers.
Most of the reason for the size limit I belive is that there axles are actually a two piece set up that is welded at the hub. So there is a limit to extra stress.
But in your case the failure was at the bearing not the axle breaking itself. So you should be able to just replace the bearing and the outer seal. You might also call 4WH and see if than can tell you how to identify their axle. If it turns out to be one of theirs then you can order from them. Moser should be able to do the same.
If I rember right the 4WH axles are OmixAda's so you might be in luck with that.
Basically there are the superiors, mosers, Omix-Ada, and then to a lesser extent warn's and summers brothers.
Sorry that I cannot help more than that.
Carl
"Stuff happens"
I wouldn't worry so much about tires size etc. as the culprit, I had the exact same thing happen to a Ford Dually I used to own. Except I managed to get stopped before the axle slipped all the way out.
Things wear out and break apart. Put it back together and keep going.
Bill
Since Sunday morning I've had 6 people tell me they have experienced the same thing. I've seen a car or 2 on the side of the road or @ shops which had apparantly had the same problem, but never knew anyone to whom it has happened. Must be more common than I realized.
Well my axle shafts turned out to be Mosers and were nearly new - maybe 15000 miles of use. The drivers side is the side which broke (the bearing is what broke). The axle shaft was badly scored and discolored from intense heat. The end of the axle housing was full of sludge - well not full but there was sludge present. The scoring and sludge are indications that the problem had been there for a while before it actually gave way and broke. I had not heard or felt anything unusual except that it had begun to steer a little funny like it was drifting and it had begun to pull when hitting seams or ruts in the pavement. I wonder if rear axle had been causing this since the scored area was about 2" at the inside of the hub. It could have caused drift without moving far enough to disengage the splines completely on the other end of the shaft.(?) The splines showed no sign of wear. I had the steering checked out recently when I had the lift kit installed and a piece of the linkage was replaced and it had been steering fine until a couple of weeks ago. Also the drop put the body in a bind which caused the rear hatch on the top and the tailgate to move to the point that they will have to be realigned which is no problem. It put some chips on stressed areas of the top and caused the top to shift a little. But in about a month I'm putting the soft top back on. It also buckled the new paint on the doors just above the top hinge. The doors were restored and professionaly painted back in October so there goes a bundle for the paint job.
Yesterday I ordered a new set of Moser 1 piece axle kits so by Thursday or Friday I should be back on the road again.
Ah, the joys of Jeephood!
I experienced the same thing in my CJ5 with the factory D44, not a good thing, glad you are ok.
I seem to recall that some of the one piece kits were using some off brand bearings for a while and you had to specifiy timkin as a part of the kit and pay a premium. Perhaps the PO had isntalled the cheapest kit he could find and the poor quality bearings were the only real causal facotr in the failure. Hopefully the axle and housing are ok, my housing was and axle wasn't.
tr
Maybe, but....
trust said:
I seem to recall that some of the one piece kits were using some off brand bearings for a while and you had to specifiy timkin as a part of the kit and pay a premium. Perhaps the PO had isntalled the cheapest kit he could find and the poor quality bearings were the only real causal facotr in the failure. tr
FWIW: I had a rear axle seal go bad about two months after Oak Ridge last Oct. Found that same brown sludge in the axle housing from water having gotten in - guessing the water crossing at Oak Ridge. I was lucky in that the seal went before the bearing and I got it (and bearing) replaced as soon as I noticed the leak.
Mechanic told me if I had checked/flushed the differential soon after the water getting in, the seal & bearing probably would not have been trashed. :eek:
My takeaways: 1) Make sure you know where your vent hose is located before doing a water crossing; 2) #1 notwithstanding, spend an hour and $5.00 to flush differential after wheeling where you did water crossing(s); and 3) address lube leaks (not necessarily seeps) asap.
Those three lessons cost me about $120... EACH!:mad: But, I won't make them again!:rolleyes:
Glad you and daughter are okay. Must've been pretty freaky seeing your tire rolling by... Yikes! Had that happen to me in a USMC Hummer about 20 yrs ago... (good campfire & cigar story:D )
I know that the PO installed the axles and no older than they are I'm pretty sure that they came with Timkins. He did a good job on all the work he did or had done and looks like he used good parts everywhere. But I'm pretty sure I let a local mechanic replace the bearings and seals a while back because I was seeing oil on the inside of the tires. I talked with him on Monday, but he seems to think he did not replace them. I'm just about positive that he did because I remember him talking about how much they cost, and they weren't leaking anymore prior to the "spill'. Since he got them locally they had to come from NAPA, CarQuest or the Jeep dealer. But the new ones will be Timkin.
I'm extremely glad I had just rounded a corner and was still in 2nd when I let off the gas to pull over. I was only doing about 10 - 15 mph when it dropped. Imagine if I had been cruising down the 4 lane at about 70! Think I'll increase my insurance too.
So far I've not been in any water other than puddles on the pavement. It's possible the sludge came from the dirt on the shoulder of the road when I limped off the pavement. But it's black, not brown. When I take the new shafts to the shop I'm going to make sure they flush it good and remove the housing cover just to make sure before doing the installation.
Advice
Check with the Manufactor on this:
Some axles have a inner seal at the end of the housing that sets just inside the bearing,some companys require it to be there and recomend that you pack the end of the housing and bearing with a high quality high temperture grease,others will recomend that the inner seal be pulled out to allow the gear oil to reach the bearings to help keep them lubed.Not all axles had these seals,some do and some don't,mine had them and i pulled them so the gear oil would keep the bearing lubed,i also packed the bearing with the best grease i could buy.Here is another little trick that i learned,drill a hole at the end of the housing,tap it and install a grease zert,make sure that it's not protruding into the area where the bearing sets,this way you can give it a shot of grease from time to time,just becarful and don't shoot to much in there or you can blow the seals-JC;)
Mules,
Thanks. I'll check into that when I pick up the new shafts which I hope will be this afternoon. With luck I'll be back on the road by tomorrow afternoon.
