Scrambler going SOA
BadDogJeep
I am doing a conversion on my '82 scrambler. I am going with a D44 3/4 ton frontend and 14 bolt rearend. I have installed 2.5" wrangler springs and made my own full width kit. If anyone is interested just drop me a line. Here is a sneak preview. See ya, Keith.
Paint
It may not look like much but it is solid and I honestly believe I will finally be able to have a paint job worth washing and keeping it clean. (Yeah Right!) I am torn between painting it the forest green (a little greener than drab) or putting a factory color such as a red or yellow. I have been putting stock into Krylon for the last few years and kinda want something better! It seems that everyone that I have met on the board is nice and interested in what each other is doing. I will be getting some more shots but this is just the axles setting in place. I hope to have everything welded up and painted in the next couple of weeks! As you can see by my avatar, it is changing daily. Here are a few specs.
Dana 44 3/4 ton frontend with 4:10 gears with locker (right now)
14 bolt rearend with 3:73 gears open carrier (right now)
258 straight six ( I have a 360 just dying to go in)
T-4 (I have a 727 Torque Flight auto also just dying to go in)
D-300 ( gonna build my own twin stick)
Wagoneer driveshafts cut down
8274 Warn winch
I hope to be in the woods in a month! :D
Try not to make it look exactly like mine.
attachment.php
3/4 ton d44 with 4.10s welded diff
D60 with 4.10s welded diff
Custom springs
258
T-4
RyanBuilt drive shafts
35x14.5 SSRs
Axle Width
What width of axles are you guys all running (wms to wms)? Im looking for 1 ton axles for my 83 CJ8 project, but may settle for 3/4 ton front. I've kinda been looking for axles from a 70's dodge, because they have a width of 64". Sorry for asking questions on someone elses post, but Im looking to do just what you guys are doing.
58" Rear
59" Front
from the face of the axle (where the wheel studs are) to the other face.
I'm not sure what my outside of the tire to tire width is though, I'll measure it tonight after I finish replacing my Steering box!!
Mark
67" rear, 69" front. But I use skinny wheels with lots of BS, so it looks about like 65" and 63" compared to a jeep with normal 10" wide wheels.
The dodges I've measured were 67" front and 64-65" rear.
