Scrambler measurement from Dash to Tailgate
bg2pres
Houston
TX
I need this measurement.
I think my body shop screwed up.
Start from the dash and measure rearward to the tailgate.
I need several measurements to see what is right one.
THANKS!
After climbing over all the crap I keep piling up around mine, I got 102.5" I measured from the dash to the top lip on the tailgate. What measurement do you have?
Just measured both of my tubs in the garage and got 102.5 as well from the dash to lip of tailgate. do you need any different measurements?
Truck
102.4- My tailgate must be off a little.
No, well, my body mounts (middle of bed) are off about 1/4" and I can't bolt them in. Also the rear corner panels are raised up so the bed rail is flat (level) until it almost hits the rear corner panels and then goes up, meaning if I put a full hard top on it or a full soft top, then there will be a gap under the base of the top just in front of the corner panels. Does that make sense???
__________--------
Back to the body shop! Just wanted to check everything else before they rip it out and do it again.
They don't understand that when I mean perfect, I MEAN PERFECT... I am anal that way. When and if I sell this thing, whoever buys it will know that it is perfect. Not just about, but smack dab on!!!
Okay, mine is 103" from dash to tailgate with the brand new tailgate weather stripping on it. It is 102" to the rear panel lip.
I also checked front the windshield lip to the rear panel lip and it is 97 and 3/4"
It is very close if not dead on.
Can anyone check the space between the side of the bed and the rear roll bar foot.
I have 1 1/4" ....
What about the measurement from the dash to the inside lip of the corner panels (front to back measurement)... We have the tailgate, but what about the corner panel. I guess they should be the same, but would rather be sure.
