Scrambler on a budget
Your 8 looks great!! Love the color. My son wants me to paint my YJ that color. Hopefully you will find a job and get back to your build. That Jeep needs an OM617! Great engine and decent fuel mileage.
Just read thread from begining to end. WOW! Inspired, excited, want to go out and do something, anything... Just need to get to garage. -20 degrees tonight and I think I will wait a bit... Back to football. I will use your build thread often!
Merry Christmas.
thanks Padre and Merry Christmas to u as well, 30 deg. here that must be like a heat wave for you HAHAHA
No problem- just googled the distance from newton to Barrie and it would only take 7 hours and 46 minutes of driving to see your incredible 8. But seeing that Christmas is upon us and that all Canadians must stand prepared to help Santa at the North Pole I won't be able to make the drive any time soon.
Great build and great looking Scrambler. Just read through the whole thing. I guess I need to get busy on mine. What size lift and did you re-gear? Also, what did you paint the frame with? I hope I didn't miss that somewhere along the line. If I did, please forgive me.
thanks
3" black diamond suspension lift with 1 " body and 1 " boomers
4.56 gears with arb lockers
paint cant remember haha but its in there somewhere. i think its tractor supply black for tractors, its cheap and did a great job. still looks good, just muddy for now; the hose is frozen solid now
Thanks, Dummy me, I just saw the lift and gear size in your signature. :banghead: Guess its time to go to bed. :crazy:
its hard to believe i've had my 8 almost 4 years now.
im driving it more now and enjoying it alot. it becomes a true hanger queen the first time they salt the roads and last year was a very long winter. i have had only a few issues go wrong.
the first was the windshield wiper linkage bound up and fried the carbons.
that was a no cost fix, i kept my orig. motor and made 1 good motor out of 2. then straightened the linkage and all is good.
next was the heater box. it was hooked up wrong when i got it and i stupidly never messed with it till now. i now know nothing was really wrong with it except the cables were on wrong. this thread helped me http://www.jeepforum.com/forum/f8/heater-vent-system-cables-diagram-1907226/
i R&R the box and resealed it. i replaced only the front fresh air flap gasket and bent the flappers inside to get them to work like new again.
windshield down is a blast
i bypassed the core thinking it would take a long time to finish repairs.
before
remove 3 cables, 4 nuts on the firewall 7/16ths, bellows tube and it falls out.
the tear down for me was like xmas, nothing was really wrong.
the fresh air section was needing repair. i used home depot truck cap sealing gasket.
cleaned, silicone sealed and armorall
the threads were hard to get off without pb blaster and some luck. i cleaned the threads with a die.
all finished, just need to stuff the stereo wires back. the defrost bellows tube is damaged so i need to duct tape it or find a replacement b4 the fall weather sets in.
i bet some of you are wondering why i didnt do the YJ / Blazer blower upgrade.
i couldnt find a good price on one local or internet, my die grinder is broken and i would need to buy / find thick foam gaskets. i figured my motor works very well is quiet and the amount of time i actually use the blower it is very little. its also DONE in a few hours.
next repairs will probably be the motorcraft 2100 carb i have to rebuild / install or the P/S hoses.
hope you all have a great summer.
Yep count me on blazer motor puzzlement, but if you're happy it's all good!
Glad it all works now. And yeah. That bellows piece to the defrost vents is a PITA. And brittle.
Dain
Dain
i got some black duct tape tonight and wrapped that PITA duct. the job inside the cab is now finished. i'll get new heater hoses next week and its ready for the cold.
cdvcj8 when that blower dies it will be replaced with the better motor. i just cant throw away stuff that works, and now that its all buttoned up, the air flow is not half bad.
time for some brainstorming on an engine swap
my clutch is now chattering in 1st just like its been doing in reverse for the last 4 years. its now on the last few threads of adjustment, and i think it could start slipping at anytime. the stock T-4 is 100% ok but too weak to keep, i dont feel like i can abuse it offroad
the 258 is 100% ok just no real power on my 4200 Lb rig. the clifford upgrade is $$$ more than the SBC when i figure in the 2.02 / 1.64 valves and other head work also i didnt want to mess with a header long term. i still have the 6cyl sound and its down on power compared to the SBC
i would rather put the time and $$$ into a SBC swap than a clutch job / MC 2100 carb swap. but i might have to if i cant get the funding. its would be the cheapest at about $300 providing the flywheel is ok
i need a stout trans regardless of what i decide.
my thinking is a Gen 3 SBC 5.3L all aluminum block and heads code L33. $750
flywheel, motor mounts, radiator, adapters, intake & carb, clutch stuff, etc. = lots more $$$
4bt would be way too much $$$ and the om615 not enough power so thats out.
the trans i havent nailed that down but would like another manual.
if i do it in steps i would waste $$ on parts like bell housing & clutch parts so its all in or nothing IMO
i hope to sell my boat to fund the project.
what do you peeps think???? what am i forgetting????
thanks
SBC is an option but if you're going the V-8 route how about a AMC 360/T176. They're cheap and much of your AMC stuff will stay. Plus I think my 360 sounds better than a chevy anyway.
X2 on the 360.
jeeeez why didn't i think of the 360 great idea thanks guys. i know why its that im a chevy guy at heart.
im starting to do some more reading.
since when cant we edit posts ???
anyway i now know i know nothing about AMC engines. 304, 343, 360, 401
best flowing heads, valve sizes, what engines had the best crank [ forged ]
if i do this i dont want to make an uneducated mistake. its got to sound good and be a torque beast.
and to top it off tonight i cant find any engines without a vehicle behind it.
i did find a rusty 79 cj-7 304 3 speed. i could do a double swap and not waste anything. sell the 79 with my 258 cj8 drive train
