today i decided to do the mechanical advance flip that jeephamer wrote about here
http://www.jeepforum.com/forum/f8/working-your-distributor-how-tune-973904/
it was very easy however i recommend removing the dizzy to do anything to it. they are so easy to remove and install if you mark and remember how it came out.
mark the cap extender on #1 cyl .. remove the cap, crank till rotor points to #1. where you just marked it. remove the dizzy.
i always work on stuff with small parts in a box [ closed bottom LOL ] and a magnet!!!
mark the roll pin location and carefully pry the armature off. i had to remove the screws and e clip to make everything loose. this way nothing got bent.
remove the springs then the felt and the clip holding the advance arm in. here its in the stock 6.75 position
now its flipped to the 7.75 position and i also removed the plastic stopper on the arm
i cleaned it all up inside and made sure it didnt bind. i had some worn out stuff i had to remake but nothing serious.
i use RUG so i can only get 8 deg. advance. 10 deg it will ping badly but at 8deg i can be in 4th at 1k rpm, and floor it without any pinging. so its "safe" as jeephammer says.
jeep runs WAY better with all the mods i did this past 30 days but im disappointed that i didnt have a pre computer dizzy. i only got 1 degree mechanical advance. i'll look around the scrap yards an may get lucky on a dizzy. at least now you all know how to do it
